gaga je napisao(la):
1.8 Turbo je motor...
vec u startu 180 PS...i jos male dorade i ide preko 200...
Ide od 150 a ne od 180 ks
1.8 20VT 110-176kW
This version is a 1.8 L turbocharged engine built in Puebla, Mexico, Győr, Hungary, and Wolfsburg, Germany. Output varies based on ECU software, turbocharger and internal component selection.
Engine code
AWM / AEB / ATW / AWD / AWW / AWP / AMU / AMB / AGU / BAM / AYP / AUM
Configuration
1,781 cc (108.7 cu in) inline 4
Head
DOHC, aluminum, 5-valves per cylinder, hydraulic bucket tappets, 9.5:1 compression ratio
Cylinders
bore * stroke 81 * 86.4 mm, cast iron engine block
Pistons
Forged Aluminium Mahle, fracture-split forged steel connecting rods, one-piece cast or forged crankshaft
Fuel System
Motronic ME 7.5 electronic multipoint sequential fuel injection, premium unleaded recommended
Aspiration
turbocharged, intercooled, cast aluminum intake manifold.
Red Line
6500rpm Limit 6800rpm
Output
110 kW (150 PS) @ 5,800 rpm and 220 N·m (162 lbf·ft) @ 2,200-4,200 rpm; available on the Passat, New Beetle, Bora and Golf. Also on the Audi A3 (first gen.) and Audi A4, Škoda Octavia and SEAT Ibiza. (Engine codes: AEB, AGU, AWD, AWW, APH, ATW)
120 kW (163 PS) @ 5,700 rpm and 225 N·m (166 lbf·ft) @ 1,950-4,700 rpm; replaced the 150 PS version in 2003 on most models.
125 kW (170 PS) @ 5,900 rpm and 225 N·m (166 lbf·ft) @ 1,950-5,000 rpm, available on the Passat and Passat Wagon. This version only exists on North American and emerging market engines.
132 kW (180 PS) @ 5,500 rpm and 235 N·m (173 lbf·ft) @ 1,950-5,000 rpm, available on the VW Golf GTI, Bora/Jetta, New Beetle, Audi A3, A4 and TT, Škoda Octavia RS and SEAT León and Toledo. (Engine codes: AWP AUQ)
Remapped power available 200 - 225 bhp (dependent on tuning company on standard engine components )
140 kW (190 PS) @ 5700 rpm and 240 N·m (177 lbf·ft) @ 1,950-4,700 rpm, available on the Audi A4 and TT.
165 kW (225 PS) at 5900 rpm, 280 N·m (207 ft·lbf) between 2200 and 5500 rpm; used in the Audi TT and SEAT León Cupra R. This version is built in Győr.
176 kW (240 PS) @ 5700 rpm, 320 N·m (235 ft·lbf) from 2300 to 5000 rpm, used in the 2005 Audi TT quattro sport, (9:1 compression ratio)
references
Audi AG (2005-02-22). "Audi TT quattro sport Revealed". Press release.
[edit] Awards
Was placed in the 1997, 1998, 2001, 2002 and 2003 annual list of Ward's 10 Best Engines.
