Chuza druze ti grijesis bez ljutnje znam sta sam uzimao, muzika je davno radjena u caraudiu ugl u nekoj trampi je i dobijena a sve jer radjeno po mjeri tako da kutija nije mala a i evo specifikacija woofera i model koji je
Pioneer TS-W5000SPL 12'' Sub
Interlace Carbon Fiber Reinforced IMPP Cone Woofer
Wide-Roll Woven Aramid Fiber Radial Rubber Surround
Overhung Surround Design
Ceramic-Coated Coil Wire
Dual 3" High Inductance, 4-Layer, Long Voice Coil (2 x 4ohm)
7-Slit Glass Imide Voice Coil Bobbin
Precision Double Conex Damper with Damper Rings
Projected Pole Yoke with Vented Pole
Aerodynamic Magnetic Gap (ADMG) Design
Massive (320oz) Triple Stacked Magnets
Thick 1.2" (30mm) Top Plate
Aluminum Die-Cast One-Piece Rigid Chassis
8-Gauge Wire Terminal
Specification:
Watts MAX. Music Power 5000W
Watts Nominal Power Handling 2000W
Frequency Response: 18Hz ~ 2kHz
Sensitivity: 88dB
Ohm Rating: DVC (2ohm or 8ohm)
Recommended Enclosure: 1.5 Cubic Feet
a i bice slike ovih dana kad sve fino poslikam i woofera i ostalih komponenti..
A sever1n druze hvala ti aa razmisljao sam nekada kad izleti da mijenjam sve tapacirunge na vratima i ovaj donji dio na instrumentalci tj trebalo bi biti crno ali to nije prioritet..a naravno cujemo se kafu da pijem red je
Specification:
Sensitivity: 88dB
