The sports car, capable of more than 400 km/h, is driven by a 16-cylinder mid-engine, that at 710 mm
long is no larger than a conventional V12 unit, and due to its lightweight construction weighs only
about 400 kilos. Its compact dimensions are due to the unique arrangement of its cylinder banks in
a W configuration.
Two VR8 blocks, each with a fifteen degree bank angle, are joined in the crankcase
to form one engine. Both eight cylinders are set at an angle of ninety degrees to each other and are
aspirated by a total of four exhaust gas turbochargers. The engine delivers 1001 HP at 6,000 r.p.m.
and provides a maximum torque of 1250 Newtonmetres at between 2,200 and 5,500 r.p.m.
To apply the power of the 64-valve unit to achieve satisfactory driving dynamics both in everyday traffic
and on the racetrack, the Bugatti development team of Dr. Franz-Joseph Paefgen and Dr. Wolfgang
Schreiber has realized a propulsion unit that is without parallel in its complexity. If the extreme
engine power is a master stroke of genius, its conversion for road use is an equally tough challenge.
As Dr. Schreiber says “For 1000 HP propulsion power, the system demands approximately 2000 HP
to be additionally generated as heat energy during combustion. Half in each case is dissipated in
the exhaust gas and cooling water”.
a na pocetku teksta pise
"from Bugatti Press Release". ako ti znas vise od njih, onda ti svaka cast...
MTR je napisao(la):
4 motora po 4 cilindra , mjenjac je Rikard / Engleska , ( DSG je Borg Warnerov a ne VW-ov ) , ima 4 hladnjaka motora , 2 od klime , i po jedan hladnjak ulja mjenjaca, diferencijala i motornog ulja.
zamisli sad ako mozes tehnicki kako bi izgledalo auto koje ima spojena da V8 motora u jednom redu , pa bio bi mu rep 1,80 metara dug .
i da , mislim da spadam u onih 0,01 % koji su ga vidjeli / sjedali
PS. ovo nije V16 vec W16 motor
ne kontam ti ovo... :icon_question:
