RE: VW Polo 6n2 " Franz " ,,UPDATE ,,
evo jedan mali update
bilo je malo farbanja
felgice postavljene RH Classic 15" naprijed 7j (195/45) nazad 8j (195/50)
naprijed stavio dodatak od golf mk3
provukli se novi kablovi od 50mm2 i dodalo se jos malo kablova
uzet novi woofercic i pojacalce :icon_smile:
Ground Zero GZNW 15"
power handling: 2500 WRMS
impedance: 2 x 2 ohm
voice coil: 75 mm / 3"
excursion: X max. 50 mm / 2"
resonance frequency: FS 37,8 Hz
SPL: 91 dB
additional: VOXR surroand triple spider
Jackson Big Killer mk3
900W-4 Ohm RMS
1500W-2 Ohm RMS
2000W/1 Ohm RMS- Power max. 4000w
Input-output, subsonic filter, zaštićeni terminali, mogućnost linka, S/N - 70 dB,
Input Level od 0,2-5V,
Subsonic Filter od 10-50Hz,
LPF od 40-220Hz,Filter 24db,
Bass Boost Freqkvencija od 30-80HZ,
Bass Boost od 0-12dbLevel
težina 7kg,
