To je zato što imam odličnu paricu, vjerovatno je u top10 u Federaciji.
Noise
Evo kako ćete ocijeniti vašu:
Margin (AKA Signal to Noise Margin or Signal to Noise Ratio)
Relative strength of the DSL signal to Noise ratio. The higher the number
the better for this measurement. In some instances interleaving can help
raise the noise margin to an acceptable level.
6dB or below is bad and will experience no synch or intermittent synch
problems
7dB-10dB is fair but does not leave much room for variances in conditions
11dB-20dB is good with little or no synch problems* (but see note below)
20dB-28dB is excellent
29dB or above is outstanding
* Note that there may be short term bursts of noise that may drop the
margin, but due to the sampling time of the management utility in your
modem, will not show up in the figures.
Line Attenuation
Measure of how much the signal has degraded between the DSLAM and the modem.
This is largely a function of the distance from the exchange. The lower the
dB the better for this measurement.
20dB and below is outstanding
20dB-30dB is excellent
30dB-40dB is very good
40dB-50dB is good
50dB-60dB is poor and may experience connectivity issues
60dB or above is bad and will experience connectivity issues
DSL Rate ***/tx/rx/Rate
The actual service data rate that your ISP has provisioned.
Attainable Line Rate
This is the maximum rate at which your modem can connect to the DSLAM if
there was no service provisioning limiting the bandwidth. The higher the
number the better.
Output Power
How much power modem (upstream) or DSLAM (downstream) is using.
Maximum recommended is about 15dB. The lower the power the better for this measurement.
