Soundstream XXX-15000D
Mala maca neki bi rekli , high end amplifier sa pokojim wattom viska
* Power Rating: 10,000Wrms @ 1 ohm @12.0V
* Power Rating: 13,000Wrms @ 1 ohm @14.4V
* Power Rating: 14,400Wrms @ 1 ohm @16.0V
* Efficiency: 78%
* Rail voltage: +/- 140volts
* Four 0guage + and - inputs
* Two 8guage remote inputs
* Four pairs of 8guage speaker outputs
* Maximum current draw: 1400amps
* Idle current draw: 8 amps
* Damping factor: >1000 @ 100Hz
* Bass boost: 40Hz - 120Hz
* Subsonic filter: 10-50Hz
* Lowpass filter: 35-250Hz
* Input sensitivity: 6V
* 2.5MM thick circuit board
* Weight: 83 pounds
* Dimensions: 12" W x 2" H x 32" L
kazu da je same board as Cactus LT12, Hertz MP15K
imageview_original.php
imageview_original2.php
