Sund Magus x1502
650kn
Features
1500W RMS Class-D amplifier
1 ohm load stable
Double Side PCB and SMD components
Adjustable Input level, LPF, Subsonic, bass boost function
Advanced short circuit, overload, over heat and low voltage protection
Heavy duty terminals
Optional remote controller
X1502 can be bridged with same amplifier through single RCA cable
Dimension - 228mm*376mm*52mm (W,L,H)
Protection System
Overload - Protect less than 0.7Ohm loads at full scale output power
Short Circuit - Full rated power short circuit protect test: passed
Over temperature - Protect while inner temperature over 80 degree C
Low voltage - Protect while power supply voltage lower than 7.8V
650kn
Features
1 ohm load stable
Protection System
