Problem novi
Problem novi
Magnat TRIBAL X FOUR
Max power output into 4 ohms 4 x 200 Watts / 2 x 500 Watts Max power output into 4 ohms
RMS power output into 4 ohms 4 x 65 Watts / 2 x 170 Watts RMS power output into 4 ohms
Max power output into 2 ohms 4 x 250 Watts Max power output into 2 ohms
RMS power output into 2 ohms 4 x 85 Watts RMS power output into 2 ohms
Max power output into 1 ohms Max power output into 1 ohms
RMS power output into 1 ohms RMS power output into 1 ohms
Freqency response 5 Hz - 50 kHz (-3 dB) Freqency response
THD < 0,05 % (1kHz) THD
Signal-to-noise ratio > 100 dB Signal-to-noise ratio
Input sensitivity 0,4 V - 4 V Input sensitivity
Input impedance 20 kOhms Input impedance
Power Supply 12 V Power Supply
Dimensions 380 mm x 52 mm x 290 mm Dimensions
Weight 3.75 kg Weight
Specials
Specials
Manual Manual
Accessories Accessories
Datasheet Datasheet
i
Pioneer SUBWOOFER TS-307D4 1200W
Features
*size 12"
*specifications
*Diameter: 300 mm
*Max Power: 1,200 Watt
*Power Rating: 400.0 Watt
*Noise Level: 89 dB
*Min Frequency: 18 Hz
*Max Frequency: 500 Hz
*composite IMMP cone using interlaced aramid fiber
*3-layer,fiber woven radial surround
*singlarge conex damper with damper ring
*dual 4-layer,long voice coils(DVD)
*double stack high power magnets(2.4kg/83oz)
*extended and vented pole yoke
*integrated single side silver binding posts
*spoke grille compatible(UD-G307)
eto sad me zanima kako je najbolje spojiti po vama da se izvuce maximum iz obadvoje bit ce u bass reflex kutiji sa orginalnim dimenzijama i portom
RE: svaki savjet dobro dosao
Svaki Bridge na po jednu zavojnicu, tako imas najvise snage na wooferu..
ja nebih tako spojio jer nema sanse da ustimas oba kanala tj mosta da rade jednako. radit ce ono nema frke ali ....
i BTW DVC subovi trebaju monoblok i tacka. zato i jesu izmisljeni i jedni i drugi.
Tko zna koliko je stabilan na bridge 2 ohm.. za takvo nesto bi trebalo sub 2x2ohm ili 1x4ohm..
IGY
prodaj obadvoje i uzmi nesto sto odgovara jedno drugom :cool:
RE: Novi Problem
e ovako ljudi bilo spojeno na 2 oma i stavljeno u funkciju i desilo se da se grije puno i osjeti se miris plastike kao da gori ja sam odma pomislio prvo iz kutije i izvadio ga da vidim sta je magneti onako nisu vreli nego nezz da ocijenim mozda otprilike 40- 50 stepeni toplota i iz magneta dopire miris pomenuti i otpojio sam sub skroz stavio samo jednu zavojnicu na 4 oma spojio i vratio u drugu kutiju i ponovo sve po spajao slusao 2 sata skoro pa na max bas radi testiranja i nista se nije desavalo manje se grije i nema vise ja mislim onog smrada. dok prethodni neizlapi :icon_smile:
e sad me zanima sto je se to desilo do cega moze biti nekontam sva podesavanja na pojacalu su ostala ista nista nisam dirao :icon_question:
Sky
kad naletis u doboj, cuj se sa denijem ili davorom, neka ti oni pokusaju pomoci....
