Potrebni strucnjaci
Potrebni strucnjaci
Eh ovako,,nakon duuugoog trazenja po netu nadjem ova dva amp-a,,pa se dvoumim koji li je bolji.Cekam da mi se jave brperi pa da cujem njihovo misljenje.
Prvi amp je:
Hifonics ZRX3000.1D
Zeus Series Single Channel Monoblock Class D Car Amplifier
RMS Power Rating:
4 ohms: 750 watts x 1 chan.
2 ohms: 1500 watts x 1 chan.
1 ohms: 3000 watts x 1 chan.
Max power output: 3000 watts
Pulse Width Modulated (PWM) MOSFET power supply
LED power (blue) and protect (red) indicators
Wired HFR-3 remote bass level control included
Variable Bass Boost (0 to +10 dB bass boost at 45 Hz)
Blue illuminated Hifonics badge
Soft start sound function
Mono channel operation
Preamp RCA outputs to daisy chain multiple amps
4-Way System Protection circuitry (thermal, overload, DC, and speaker short protection)
Dual 12 gauge speaker terminals simplify hookup
Heavy duty aluminum alloy vented heatsink for maximum heat dissipation
Silver nickel-plated RCA level inputs
Silver nickel-plated screw terminals
Input sensitivity:
Variable level: 200mV-6V
Variable low-pass filter (30-250 Hz, 24 dB/octave)
Subsonic filter (15-35 Hz)
Damping factor: >200
Frequency response: 15-250 Hz
0-gauge power and ground wiring is required for installation. Contact us for information regarding a discount on select amplifier kits when purchased together with this amplifier.
Drugi amp je:
RE Audio XTX-5000.1
XTX Series Monoblock Full Digital Car Amplifier
RMS Power Rating (14.4V):
4 ohms: 1000 watts x 1 chan.
2 ohms: 1700 watts x 1 chan.
1 ohm: 2500 watts x 1 chan.
Dynamic power output: 5000 watts
Pulse Width Modulated MOSFET power supply
LED power (green) and protect (red) indicators
Wired remote included
Selectable bass boost with frequency control (0-12 dB at 30-80 Hz)
Single channel operation
2-Way System Protection circuitry (thermal and short circuit)
Heavy duty brushed aluminum alloy convection cooled heatsink for efficient heat dissipation
Nickel-plated RCA level inputs
Nickel-plated 8-18AWG screw terminals
Input sensitivity:
Low level: 100mV-6V
Variable low-pass filter (40-180 Hz, 24 dB/octave, Butterworth)
Subsonic filter (17-50 Hz, 24 dB/octave)
Signal to noise ration: 90dB
Phase Shift Control: 0 - 180°
Frequency response: 17-180 Hz
Dimensions: 9-1/4"L x 20-9/16"W x 1-15/16"H
1/0-gauge power and ground wiring is required for installation. Contact us for information regarding a discount on select amplifier kits when purchased together with this ampl
Cijena im je tu negdje slicna,, 500 watt je razlika,,sad koji bi se bolje pokazo za BRP :icon_question:
posto niko neodgovara,,a ja jos vise rovio po netu,,naso sam odgovor HIFONICS COLOSSUS :cool::cool:
stavljajte katanac ovdje :D
