koliko vrijedi ovo pojacalo kicker zx200.2 i dali mi moze dovoljno gurati prednje sisteme recimo dls c6a ili r6a... ???
Amplifier Type: 2-channel
RMS Power @ 4 Ohms: 70W x 2 @ 14.4V
THD at 4-Ohm RMS Power: <1 %
Bridged RMS Power @ 4 Ohms: 200W x 1 @ 14.4V
Speaker Level Inputs: Yes
Preamp Outputs: Yes
Built-In Crossovers: HP/LP
Bass Boost: 0-18 dB
Frequency Response: 20-20,000 Hz
Signal to Noise Ratio: 98 dB
Fuse Rating: 30 amps
Advanced chassis with extruded aluminum heatsink
MOSFET class A/B power supply
Top-mounted controls
KickBass 0-18 dB variable bass boost at 40 Hz
Variable 50-200 Hz high- or low-pass crossover with 12 dB/octave slope
High level or low level inputs (125mV-10V)
PreAmp Signal Transfer (PAST) RCA outputs
Delayed turn-off logic circuit
Soft start turn-on circuit for reduced startup load
Short circuit, Over-voltage, Reverse polarity, Thermal overload (SORT) protection
Fully CEA-2006 compliant specifications for real-world power
EDIT: Sjeba se ja oko slike...
Preamp Outputs: Yes
Bass Boost: 0-18 dB
