Prodajem vrhunski monoblok Xetec Gravity G-1200 mk2!
Pojacalo je bukvalno kao novo,samo probano 15 minuta na SoundLunaticovom Alpine-u 15-ki...:icon_biggrin:
Posjeduje i kutiju,uputstvo i prateci materijal.
Cijena je minimalna i fixna za ovakav uredaj,a to bi bilo 300 KM !!
Zamjena eventualno za neki mobitel do pola vrijednosti pojacala,a ostalo pare... pozz
RMS Output power @4 Ohms: 450W
RMS Output power @2 Ohms: 750W
RMS Output power @1 Ohm: 1225W
Peak output power: 1500 W total
Idle current (no signal): 2,5 A
Max input Current (@13,8 V): 123 A
Fuse: 2x 40 A
Total Harmonic Distortion (THD): <0.2%
Signal/Noise Ratio (SNR): >82 dB (A)
Frequency Response: 5 Hz – 250 Hz (in bypass mode)
Full protection
Stability: >1 Ohm
Input Sensitivity: 200 mV-6 V
Crossover frequencies: 40-200 Hz lowpass 10-50 Hz subsonic adjustable
Abmessungen: 280 mm x 280 mm x 65 mm
[attachment=30372]
Fuse: 2x 40 A
Full protection
Stability: >1 Ohm
[attachment=30372]
