Prodajem sljedecu stvarcicu, isprobanu i prakticno novu, koristeno jedan put.
4 in 1 FNR key prog FNR 4 in 1 key programmer
FNR key prog 4-in-1 Key programmer for Nissan Ford Renault is available. 4 in 1 FNR key prog contains Renaul+t key prog, N_issan key prog, F+ord key prog and incode calculator for ford. FNR key prog 4in1 language is only english.
R+enault key prog N+issan key prog for Ford key prog FNR key prog 4 in 1
FNR key prog 4-in-1 Key prog for Nissan Ford Renault
For Ford key prog+ Renault key prog+ Nissan key prog+ ford incode calculator
Language: English only.
Software version:
1. For ford key prog v1.1.2
2. For renault key prog: v2.3.1
3. For nissan key prog: v2.3.1
4. For ford incode calculator:1.0
For Ford key prog
Worked for Ford key programmer 1997-2011
F_ord key programmer is an affordable, high performance, PC to vehicle programming interface,working by obd2,supporting different ford cars from 1997 to 2011 .with the ford key programmer,you can clear the keys and add new keys.
Model list:
Transit Connect (2007-2011)
Focus (2004-2011) non-prox
Fusion (2002-2011)
C-Max (2003-2010)
Cougar (1998-2002)
Fiesta (1998-2002)
Fiesta (2002-2008)
Focus (1998-2004)
KA (1998-2000)
KA (2000-2008)
Mondeo (1998-2007)
Puma (1997-2001)
Transit (2000-2006)
Transit Connect (2002-2007)
For Renault key prog
key programming and pin code retrieval system!
R_enault key prog allow you to add a blank key or card for many of NEW Renault and Nissan cars via OBD-2 socket. You DO NOT NEED any PIN code! Software would program keys/cards AUTOMATICALLY. it is for Renault and Nissan based vehicles using HITAG-2 keys/cards - with the 12 character pincode.
The programmer connects to the vehicle through the diagnostic connector, and with the PC software supplied shows the true dealer code from the vehicles. Simply click on 'Program' and it will prompt you through the programming sequence for learning new keys/cards to the vehicle.
Naturally once the Pincode is retrieved you can also use it for any security/coding/replacement of Renault body control UCH ECUs. This functionality will require a Renault Clip or DEC Superscan
This programmer is designed for pincode reading and key programming solution by OBD solution for the Renault
Advantages:
Very simple and user-friendly software interface
You do not need any PIN codes or access to Renault.net
You can program up to 4 blank keys/cards
Automatic remote control unit programming
Models Covered:
Clio II
Laguna Ph1/Ph2
Espace Ph1/Ph2
Velsatis II Ph1/Ph2
MeganeII
ScenicII (2007)
For Nissan key prog
This covers pincode reading / key programming on these car systems with a mechanical key (non proximity) to the present day.
For Nissan Micra K12
For Nissan Note
Note :Additional Securty Pincode reading / key programming for the Nissan Micra K12 and Nissan Note.
For Ford incode calculator :
For Ford incode calculator for 6 or12 character
Supported car models: For FORD CARS.
With the incode/outcode calculator, No need for internet access - this software does all the calculations for you, seamlessly in the background.
you can use the INCODE, it calculates to match PCM to PATS module when installing new or secondhand FORD diesel pumps (INCODE calculator can be used without plugging into car). And You will need another diagnostic tool FORD IDS to do Ford pump matching.
Software version:
For Ford key prog
Model list:
Fusion (2002-2011)
C-Max (2003-2010)
Cougar (1998-2002)
Fiesta (1998-2002)
Fiesta (2002-2008)
Focus (1998-2004)
KA (1998-2000)
KA (2000-2008)
Mondeo (1998-2007)
Puma (1997-2001)
Transit (2000-2006)
Advantages:
Models Covered:
Clio II
Laguna Ph1/Ph2
Espace Ph1/Ph2
Velsatis II Ph1/Ph2
MeganeII
ScenicII (2007)
For Nissan key prog
For Nissan Note
