Na prodaju navedeno pojacalo, US Blaster, model 1371, po specifikaciji daje 1000w rms na 1 om.
Zamjene iskljucene, slikice i detaljne informacije ispod, cijena po dogovoru na PM.
Mono pojacalo, D klasa, sljedecih specifikacija:
Model USB 1371
Power supply voltage 12 volt DC
(Allowable from 10.5V to 16V)
Total harmonic distortion Less than 0.2%
Output impedance 1 - 8 ohm
Input impedance 10K ohm
Input sensitivity Adjustable from 200 mV to 12V
Frequency response 5Hz—500Hz +/-1dB
Signal to noise ratio better than 80dB
RMS output@ 4 ohm 300 watt
RMS output@ 2 ohm 600 watt
RMS output@ 1 ohm 1000 watt
D-class technology
Automatic short-circuit, overload and thermal protection
Mosfet (PWM) switch mode
power supply
Heavy-duty aluminium heatsink
Gold-plated RCA terminals
Led indicator
Bass control
Large adjustable input level
Remote ON⁄OFF
Remote volume control
stable down to 1?
adjustable LOW pass filter
pre-amplifier output,
soft start.
P.S. Slike su sa neta
Model USB 1371
D-class technology
power supply
Led indicator
Bass control
Remote ON⁄OFF
stable down to 1?
soft start.
