ok
evo ispravak
Prodaje se old school SQ pojačalo u odličnom stanju
Soundstream ref604
sav info na 091 728 45 27
Excellent durability and flexibility.
Onboard crossovers, line out, BTL input...etc
High Power:
4 x 75W @ 4 ohm,
4 x 125W @ 2 ohm,
4 x 150W @ 1 ohm,
2 x 250W @ 4 ohm bridged,
2 x 300W @ 2 ohm bridged
High Current:
4 x 37.5W @ 4 ohm,
4 x 75W @ 2 ohm,
4 x 125W @ 1 ohm,
4 x 150W @ ½ ohm,
2 x 150W @ 4 ohm bridged,
2 x 250W @ 2 ohm bridged,
2 x 300W @ 1 ohm bridged
THD: 100dB
Freq. Response: 20Hz 20kHz ±0.5dB
Bandwidth: 15Hz 50kHz
Stereo Separation: >90dB
Damping Factor: >200
Fuse: Internal 2 x 30A
Dimensions: 15.25" x 9.5" x 2.25" (38.7cm x 24.1cm x 5.7cm)
cijena 1500kn
Prodaje se Aku Fiamm FLB400 svi podatci na linku,prodajem zbog promjene planova
koristi se za autoakustiku
cijena 1000 kn
http://www.setronic.dk/Datasheets/FIAMM/flb.pdf
infinity 1050w
subwoofer je kao nov
mogučnost izrade kutije
350kn
» 10" 4-ohm subwoofer
» polypropylene woofer cone with large-roll rubber surround
» innovative basket design minimizes depth
» progressive spider design for excellent cone control
» frequency response: 25-400 Hz
» power range: 60-250 watts RMS (1,000 watts peak power)
» sensitivity: 91 dB
» top-mount depth: 4-9/16"
» sealed box volume: .75 cu. ft.
» ported box volume: 1.75 cu. ft.
» Recommended Q-Logic Box Type: 1
Auto pojačalo Kenwood KAC-8405, Novo nikad izvađeno iz kutije!
1000kn
Dodatne datoteke i opis proizvoda
Opis
High Performance 4/3/2 channel Power Amplifier
4-Channel Performance Series Class AB
60 W x 4 (4Ω) (20 Hz - 20 kHz, 0.08% THD)
90 W x 4 (2Ω) (1 kHz, 0.8% THD)
180 W x 2 Bridged (4Ω)
MOSFET power supply
LED power indicators
Speaker-level inputs
Input sensitivity control
Bass boost switch
Short circuit, DC offset, overload, and thermal protection circuitry
Signal sensing turn-on
Cast aluminum heat sink design
Built-in cooling fan
Gold-plated RCA level inputs
Gold-plated screw terminals
Single side exposure of terminals for multi-installation
Variable high-pass filter (50-200 Hz, 12 dB/octave)
Variable low-pass filter (50-200 Hz, 12 dB/octave)
CEA-2006 compliant amplifier
Frequency response: 50-200 Hz
Dimensions: 11"L x 2-5/16"H x 9-3/8"D
8-gauge power and ground leads recommended.
Moguče zamjene za auto akustiku
Cijena: 1.499,00 kn U DUČANU
Magnat RX MONO--NOVO nekorišteno--1500kn
pojačalo je NOVO ne korišteno,zapakirano u original ambalažu
Cijena sa PDV: 2099.00 (Kn)--- U DUČANU
Princip Mono pojačalo
Maksimalna snaga na 4 Ohm 1000 W
Maksimalna snaga na 2 Ohm 1400 W
Maksimalna snaga na 1 Ohm 2000 W
Snaga RMS na 4 Ohm 500 W
Snaga RMS na 2 Ohm 700 W
Snaga RMS na 1 Ohm 1000 W
Frekvancijski raspon 5 - 250 Hz
Podešavajući low pass filter 40 - 250 Hz, 12dB
Podešavajući subsonic filter 10 - 40 Hz, 12dB
Podešavajuća kontrola basa na 45 Hz, 0 - 12 dB
Dimenzije (Š x V x D) 450 x 50 x 261 mm
