P: Parking senzore+displej i kamera.NOVO
Zapakovani,set sa slike.Displej se kaci na retrovizor ima ulaz za 2 kamere.Dobijete jednu kameru za zadnji branik.
[attachment=32714][attachment=34082][attachment=34083][attachment=34084]
Manufacturer Specifications
Set Includes 4 Sensors + Sensor Box, Rearview Camera, and Car Rearview Monitor
Car Rear View Monitor Specification
* Screen: 7 Inch TFT LCD
* Video Color System: NTSC/PAL (Auto Switch)
* Aspect Ratio: 4:3, 16:9
* Video Output Level: 1Vp-p 75Ohm
* Horizontal Resolution: 500 TV Lines
* Resolution: 480xRGBx234
* Video IN
* Rearview Mirror Pinch Clip: Adjustable- 60mm ~ 90mm
* Dimensions: 105mm x 250mm x 25mm (L x W x D)
Camera Specification
* Image Device: 1/4 Inch CCD
* Color System: NTSC, PAL
* Horizontal Definition: 380
* Angular Field of View: 75 deg
* Minimum Illumination: 0.0 LUX night vision via IR lamps
* Scan area: PAL: 5.18x4.19mm ; NTSC: 4.69x3.45mm
* Scan frequency: PAL 50HZ, NTSC 60Hz
* White Balance: Auto
* S/N Ratio: <50dB
* Operation Temperature: -10 ~ +50 deg C
* Connection: RCA
* Waterproof: YES
* Recommended Max Range for Objects: 5 Meters
Camera + Parking Sensor Specification
* x4 Parking Sensors + Senor Box
* Video IN (For Connecting Camera)
* Video OUT (For Connecting Camera and Sensor Information to LCD Screen)
* x4 Sensor IN
* 12V Power OUT (For Powering Camera)
* Speaker OUT
* Detect and Display Distance: .4~2M
* Voice Distance Alert from Speaker
* Exact Digital Distance Display of Obstacles on LCD Screen (Displayed in CM Increments)
* Alarm Mode - Voice Warnings at 1.2, 0.9, 0.7 Meters
* Alarm Mode - Continual Stop Warning at >0.5 Meters
Product Notes
* Camera is equipped with IR lamps, for night vision
* Polarized Monitor For Clear Rear Viewing When Monitor Off
* Remote or Touch Button Controlled
* Automatic Monitor/Camera Feed On While Reversing
* Automatic Parking Sensor On While Reversing
Package Contents
* Model CVEZJ-700HH Car Reversing Set
* Mirror Monitor
* Rear Sensors
* Video Cables
* Power Cable for Mirror Monitor
* Power Cable Set for Sensors
* Installation Tools
* Instructions Sheet - English
170 KM
061 752 304
Prilozi
    36,2 KB · Pregleda: 117
    25,6 KB · Pregleda: 13
    28,8 KB · Pregleda: 4
    29,8 KB · Pregleda: 4
Moze zamjena za woofer uz moju doplatu,minimalno 600 rms-a ili neki sistem za vrata sa visokotoncima i skretnicama.
