cijena novog je 1100KM, ovaj ide za 600KM
http://www.audiodesign.de/products/grafik/hifonics/products/hifonics/brutusb3/BrutusD_amps.jpg
BRUTUS B3 monoblocks are the ideal companions to the analog Zeus amplifiers in the same cosmetic design. With their thought-through features like Phase-Shift (0-180 °), variable Q-control and bass-boost (20-80 Hz) as well as the 1 ohm stability, they are ideal for subwoofer application. The powerful Class-D technology enables the amps to achieve high efficiency (up to 80%), they deliver lots of power but keep the electrical system in your car unburdened.
• Advanced Class-D Digital Technology
• New Class-D Chipset with high Damping Factor
• Bass Remote Controller
• Screw-type RCA In-/Output Jacks
• Molded Terminals & Maxi-Fuses
• Illuminated, switchable Logo Badge (blue/white)
• Aluminum Endpanel Frames & Controller Knobs
• Double-sided PC-Board with reinforced Copper Trays
• Lowpassfilter 35 - 250 Hz, Subsonicfilter 15 - 55 Hz
• Master/Slave-Mode with Protect Bridge,
• Extended Bass Control: Bass EQ, Freq. and Q-Factor sep. adjustable
• Phase Shift 0° - 180°
• Balanced Line-Inputs
BXi4000D
Class D Digital Monoblock
1 x 800/1400/2000 Watt RMS @ 4/2/1 Ohm
260 x 60 x 500/530 mm
BXi4000D
