P:Alpine swr 1240
P:Alpine swr 1240
Prodajem ili mjenjam za zvucnik sa duplom zavojnicom,stabilan na 2 ohma..
Zamjene nudite ovdje ili u pp...
Uglavnom svi uz google mozete vidjeti specifikacije navedenog zvucnika ali evo nije meni tesko to uraditi.Sve da prodam :lol:
http://i49.tinypic.com/9l94jc.jpg
[IMG]http://i45.tinypic.com/xn69v8.jpg
Frequency Response : 24Hz - 2kHz
Impedance (Nominal) : 4ohm
Magnet Weight : 2534g
Mounting Depth : 175mm
Mounting Diameter : 275mm
Sensitivity : 89 dB/W/m
General-Subwoofers
Diaphragm Material : Kevlar Reinforced Pulp
Magnetic Weight : 64oz.
Mounting Depth (top mount) : 175mm (6-7/8�)
Mounting Diameter (top mount) : 275mm (10-13/16�)
Recommended Box Types : Sealed/Vented/Bandpass
Recommended Sealed Box Volume : 0.7 � 1.0 cu. ft.
Spider Material : Nomex
Voice Coil Diameter : 50mm
Power Handling
Power Handling Capacity (Peak) : 1000W
Power Handling Capacity (RMS) : 300W
Thiel Small Parameters
Coil Height (Hvc) : 35.8mm
Cone Area (Sd) : 467.59 sq. cm
D.C.Coil Resistance (Re) : 3.6 ohm
Electrical Q (Qes) : 0.38
Equivalent Suspension Stiffness (Vas) : 66liters(2.19cu.ft.)
Free Air Resonance (Fs) : 26Hz
Frequency Response : 26Hz - 1kHz
Gap Height (Hag) : 10mm
Impedance (Nominal) : 4 ohm
Inductance (Le) : 2.38mH at 1kHz (0.85mH at 20kHz)
Linear Excursion (X linear) : 12.9mm
Maximum Excursion (X peak) : 25.8mm
Mechanical Excursion (Peak-to-Peak) : 55mm
Mechanical Q (Qms) : 10.39
Sensitivity : 87 dB/W/M
Total Loudspeaker Q (Qts) : 0.37
Cijena je povoljna.Za sve javite se u pp..ili na moj pik...
