P: 2x DLS MW12 sub
P: 2x DLS MW12 sub
Prodaju se subovi od DLS-a MW12, 2 komada u bas reflex kutiji ...
# Speaker type : Subwoofer
# Impedance : 4 ohm
# Size : 12" (30 cm)
# Power handling capacity : 400 W RMS / 600 W max
# Frequency range : 20-2000 Hz
# Sensitivity : 91 dB (1W/1m)
# Magnet size : 180 mm (7,1"), 140 oz
# Outer diameter : 310 mm (12,2")
# Installation depth : 142 mm ( 5,59")
# Mounting hole : 282 mm (11,1")
# Weight : 8,9 kg (19,6 lb
# X-max : +- 9 mm (0,35")
Cijena 500 KM fixno
Evo kako se radila kutija
Kutija iznutra dampirana Dynamat Extremom
Finale
