Nick Caster's '88 CRX
Evo za ljubitelje CRX, ako je bila kljuc ili brisite (ili sta vec)
Bolts & Washers
Propulsion:
B18C engine
Innovative mounts
Koyo aluminum radiator
Samco Sport hoses
Fastline Performance oil pan baffles
Mugen radiator cap
Skunk2 Stage 1 camshafts
ITR valve springs
ITR retainers
JG adjustable camshaft gears
Vision carbon-fiber spark plug cover
Walbro 190 lph fuel pump
Golden Eagle fuel rail
Earl's fittings and lines
Summit Racing fuel filter
Sard fuel pressure regulator
AEM cold air-intake
Skunk2 intake manifold
Maxbore 64mm throttle body
JG Edelbrock headers
Redshift exhaust
Omnipower test pipe
JDM GS-R transmission
Fastline Performance shifter
Energy Suspension shifter bushings
Exedy Stage 2 clutch
ACT lightweight flywheel
ITR LSD
ITR 4.7:1 final drive gear
Stance:
Omnipower coilovers
MFactory rear upper control arms
DC Sports rear upper tie bar
Skunk2 lower tie bar
Skunk2 rear lower control arms
Innovative front crossmember
ITR rear trailing arms
Resistance:
Hawk HP / Porterfield R4S pads
Wildwood Dynalite calipers
ATE Super Blue fluid
Earl's steel-braided lines
ITR rear disc brakes
Rims & Rubber:
15x7 Volk CE28 (+43 offset)
205/50-15 Falken Azenis 615
15x7 Team Dynamics Pro 1 (+40 offset)
205/50-15 Hankook Ventus Z211
ARP extended wheel studs
949 Racing lug nuts
Outside:
Autopower four-point roll bar
VIS carbon-fiber hood
PCI rear wing brackets
C-West aluminum rear wing
www.roadracegear.com air dam (street)
www.roadracegear.com air dam with splitter (track)
Inside:
Bride Zeta III seats
Wedge seat brackets
Crow six-point harnesses
Mugen steering wheel
Spoon Sports shift knob
Summit Racing kill switch
IOport rearview mirror
IOport camera mount
Cookie Monster co-pilot
Pioneer speakers
Pioneer head unit
Fire extinguisher
Props:
Sam Caster
Ryan at Rywire
Graham at Redstone Motors
Brian at PCI
Woody at Hoodfab
Innovative mounts
All the Hybrids.jp 'Squatches'
Warren at Accurate Powdercoat
Nisam siguran da li sam je ja postavljao s obzirom da imam ovu Hondu negdje na hdd-u,ali u svakom slucaju neka je,predobra je,ako neko kaze nesto protiv spojlera ubit cu se :icon_evil: :D
erol_brcak je napisao(la):
ubij se :lol:
Ko kaže nešto protiv nema pojma :D pa logično je valjda čemu služi i da je NEOPHODAN na ovom autu a i postavljen drgačije nego obično taskođer s razlogom
keeeeez :icon_smile:
fantomski odradjen... sve na njemu je odmereno i potpuno funkcionalno (mislim na spojler)...
ali od svega su najjace registarske tablice...:D
Da,vidi stvarno tablica,ali ih ne kontam,B18C je valjda iz Integre motor i taj je "vetekaš" koliko znam :icon_question:
Mislim da su tablice tako zato da se ljudi ne prepadnu kad je vide, valjda da ih tablica navede da pomisle da nije v-tec :D
P.S ne znam čemu bi služilo onda sve ovo po motoru ako nije
Meni je unutrasnjost predobra,veri lajk it i ovaj uvrnuti mjenjac pogotovo :icon_biggrin:
Sto se tice vtec or not vtec,eno pise na motoru da je VTEC,heh :cool:
