Kadett BiMoto
Kadett BiMoto
No nitro,no remap,no slick full stock engines...
210-220 km/h on 402 m
rev limiter 6400 rpm
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/cXplF3aDrjA&hl=en_US&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/cXplF3aDrjA&hl=en_US&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/zPLR24OrtpM&hl=en_US&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/zPLR24OrtpM&hl=en_US&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/V5a4jG7FPzE&hl=en_US&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/V5a4jG7FPzE&hl=en_US&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
na 6400 je limiter ali sat je od 4taka pa pokazuje vise...
trecom ide preko 200 km/h kad se salta na 7000 rpm
sad je treca 185 na 6400 rpm
220 km/h je izlaz sad na sve stock
stari motoru bez nitra su imali manje od 200 km/h izlaz,sa full slickovima sa remapom i sa svim tim vozili su 12.5 sec a manje od 200 izlaz i to trecom,cetvrta se nije ni saltala.
Sa nitrom stari motori su isli 240 km/h i to je 10.7 sec vrijeme...
pa vi sad racunajte...
Danas smo mjerili MV12,bez remapa i bez nitra samo one prepravke sa kojima smo upalili motore(usis,izduv,zamajac...)
Prednji motor je izbacio 232.7 KS i 291 Nm
Zadnji motor je izbacio 243.3 KS i 290 Nm ali zadnji motor nema alternatora
Kad se sve ustima i podesi,motori ce da imaju oko 500 KS bez nitra.
he he evo Sinisa mi je rekao da je osvanula na FB grupa svi mi koji mislimo da ce Sinisa Basta oboriti record 402 street race-a
http://www.facebook.com/home.php?#/group.php?gid=265152678152
Bacen sprickit sutra lakiranje.
Evo kako je bilo prije sa c20xe motorima + nitro i sa ukupnom snagom oko 650 ks i vremenom 11.1 sec (kasnije smo isli mnogo brze ali nemamo snikme iz kabine :sad: )
http://www.youtube.com/watch?v=8JXnfT2jM_w
Evo kako je sad sa MV6 motorima bez remapa,bez slikova i bez nitra i sa oko 470 ks ( to je za sada setup,kad se sve ustima oko 1000 ks ce da bude sa nitrom)
http://www.youtube.com/watch?v=V5a4jG7FPzE
Pa evo sad cu malo da analizairam sve ovo
Sa starim motorima, kada je ovo snimano mjenjac je kraci bio i 5. brzina je saltana prije cilja i izlazna brzina je bila preko 240 km/h (po satu) u stvarnosti manje ali sad je to nebitno jer uporedjujemo po satu.Evo slika:
Sada sa MV6 je mnogo duzi mjenjac,ovaj snimak koji sam postavio je sniman na full stock motoru a obrtomjer je bio od 4taka pa zato onoliko ide visoko a u stvarnosti je blokada na 6400 rpm.Na ove duze mjenjace auto po snimku izgleda da ide mnogo sporije nego gore ali po izlaznoj brzini gledano razlika je mnogo manja i sve se desava u 4. brzini...
Stari c20xe motor bez nitra sa full remapom i sa slickovima,su imali izlaznu brzinu cak manje malo od 190 km/h a ovi sad MV6 bez remapa i bez slickova malo preko 220 km/h
Vjerujemo da ce ovo biti zaista prebrutalan auto kad ga zavrsimo...
Cekamo da malo otopli i nastavljamo sa radovima,uglavnom do 4 mjeseca ce biti spreman u fullu
<object width="480" height="385"><param name="movie" value="http://www.youtube.com/v/i6SNjH9wEcs&hl=en_US&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/i6SNjH9wEcs&hl=en_US&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="480" height="385"></embed></object>
<object width="480" height="385"><param name="movie" value="http://www.youtube.com/v/BWhvMPeXi3g&hl=en_US&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/BWhvMPeXi3g&hl=en_US&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="480" height="385"></embed></object>
Evo i konacno snimak sa nitrom,mada je rijec o light nitro setupu opet je na snimku 4 brzina skoro do 7000 rpm stigla a to je brzina oko 260 km/h.
Snaga je ovde oko 850 ks.
Kasnije cemo pojacati snagu ali sad prvu trku u Mostaru vozimo na ovaj setup.
<object width="480" height="385"><param name="movie" value="http://www.youtube.com/v/wJpZdU8Pgr4&hl=en_US&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/wJpZdU8Pgr4&hl=en_US&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="480" height="385"></embed></object>
