FORD ESCORT cosworth...
edo
Technical data for the Ford Escort RS Cosworth.
Engine - General
Emission standard 83 US
Identification code N5F
Type Turbocharged, In-line-four
Turbocharger Garrett T35
Firing order 1-3-4-2
Bore 90,82 mm
stroke 76,95 mm
Cubic capacity (effective) 1993 cc
Compression ratio 8,0:1
Boost pressure 0,9 bars
Idle speed 900 rpm
Max. engine speed (continuous) 6500 rpm
Power output (DIN) 169 kW (227 bhp) at 6250 rpm
Torque (DIN) 299 Nm at 3500 rpm
Engine management Weber-Marelli electronic
Spark plugs (Production) Nippon Denso PK20PR-PII
(Service) AGPR 902 P
Ignition timing 16° before TDC at idle speed
Number of main bearings 5
Valve seat angle 45°
Valve timing Direct by OHC
Number of camshafts 2
Number of camshaft bearings 5
Camshaft drive By toothed belt
Engine lubrication
Viscosity 5W/50
Specification Mobil 1 or API SG/CD synthetic oil only
Initial oil fill capacity 4,75 litres incl. filter
Oil change interval 10000 km
excl. filter 3,7 litres
incl. filter 4,2 litres
Minimum oil pressure* at 900/950 rpm: 1,8 bars
at 2000 rpm: 2,4 bars
*with SAE 50W/50 oil at 80°C
Cooling system
Fill capacity incl. heater and expansion tank 7,5 litres
Anitfreeze - type Motorcraft Super Plus antifreeze
Specification ESD-M97B49-A
Use a 50/50 (% by volume) mixture when filling and topping up
kasnije još malo slika...
mocno izgleda a i pod haubom se ima sta vidjeti. gledao sam na mobile.de i autoscout.de gdje im se cijena krece od nekih 8000 pa 100 000 evrica
