svasta nesto :) ; sve iz auta i iz garaze, podruma, tavana , itd :D
Pojacala :
DLS Ultimate A6 Cijena 550 KM
Number of channels 1
Amplifier class AB
Output power in 1 ohm 1200 W RMS
Output power in 2 ohm 870 W RMS
Output power in 4 ohm 500 W RMS
Damping factor > 200
S/N ratio, A-weighted > 100 dB
Frequency range 10 Hz - 125 Hz
Input sensitivity 0,2 - 7 V
Input impedance, high level N/A
Input impedance > 10 kohm
High pass filter Subsonic: 25 Hz
Low pass filter 50-125 Hz
External cooling fan terminal Yes
Dual DC inputs Yes
Low level output No
Phase control for subwoofers 0- 180 degrees cont. variable
High level input with auto start No
Remote bass level control Yes
Remote phase shift control Yes
Integrated fan Yes
Power consumption (idle) 0,6 A
Power consumption (max) 140 A
Rec. power cable Minimum 2AWG / 33 mm2
Fuses 4 x 35 A
Dimension (W x D x H) 410 x 240 x 73 mm (16,15 x 9,45 x 2,87 inch)
Weight 6,2 kg ( 13,67 lb)
-Hifonics Zeus ZX700, 5 kanala , made in USA , 4x75 i 1x400 RMS-a 200 KM
-Rodek , 6 kanalac , 6x140W 200 KM
Wooferi :
-Rockford Fosgate RF R3112 450 KM
# FIBERlock treated paper cone with Santoprene™ rubber surround
# Frequency Response: 26-400 Hz
# RMS Power Handling: 1,000 watts (500 watts per coil)
# Peak Power Handling: 2,000 watts
# Sensitivity: 85 dB
# Dual Voice Coil Design (two 2-ohm voice coils)
# Top Mount Depth 6-7/8"
# Sealed Box Volume: 1.00 cubic feet
# Ported Box Volume: 1.75-4.0 cubic feet
-Hifonics HFI12S4 industrija 300 RMS-a 12-ka malo ostecena bila membrana , muha ga skrpio :D garancija :D 70 KM
# 12” Single 4 Ohm HFi Series Subwoofer
# Power Handling:
* Peak: 600 watts
* RMS: 300 watts
# Impedance: Single 4 ohm
# Injected poly light rigid cone
# 1” NBR Reinforced rubber surround
# High-excursion rubber surround
# Integrated one piece poly cotton spider
# Poly-mica cone damping
# Nickel plated push and insert speaker terminals
# Single 4 ohm high-temp multi-layer high-temp voice coil
# Front-plate and voice-coil cooling
# Poly light dust cap
# Heat dispersing ported back plate
# Ultra ridged chrome stamped steel basket
# High strength ABS motor cover
# High-energy magnet
# Large air cooled magnet assembly
# Anti-resonant rubber magnet boot
# Sensitivity: 88 dB
-Alpine type R sprzen , ostali dijelovi u super stanju , moguce ga premotati
500 RMS-a 12-ka 70 KM
HU
-Alpine 9880
super ocuvan + kutijica + lim 230 KM
* Full Speed Connection for iPod (optional KCE-422i required)
* Bluetooth ready (optional KCE-300BT required)
* USB Capability for Music File Playback
* CD Text Display and Scroll
* MP3/WMA/AAC playback
* CD-R/ CD-RW Compatible
* Quick Search
* 1-bit DAC
* ID3 Tag Information Display
* Zero Data Mute (0 bit Mute)
Connectivity
* OEM Steering Remote Control Ready
* AUX-IN (with KCE-236B)
Power Specification
* 50W x 4 High Power Amplifier
* 3 Preouts with Subwoofer Level Control
Display
* Dual Illumination (Green/Amber)
* 5x9 Dot Matrix Display
* White LCD Lighting
Audio Processing
* Subwoofer Level: -7 ~ +7 dB
* Bass Level: -7 ~ +7 dB
* Bass Frequency: 60/80/100/200 Hz
* Bass Q-Factor: 1~4 (1=wide, 4=narrow)
* Treble Level: -7 ~ +7 dB
* Treble Frequency: 10/12.5/15/17.5 kHz
* High-Pass Filter: 80/120/160 Hz
Other Highlights
* MaxTune Tuner
* Rotary Encoder Volume Control
* Detachable Face Plate
* Remote control ready (not included)
* ISO Connector Ready
-Sony BT5000 (bluetooth, animacije, 3 izlaza za pojacalo, AUX, mogucnost kopcanja iPod-a) fali mu dugme za izbacivanje plocice moze se nesto improvizirati , ostalo OK 130 KM
* Audio Format : BTM
* Digital-to-Analog Converter : 24bit
* Frequency Response : FM:Intermediate frequency(MHz)10.7MHz/450kHz
* Sensitivity (db) : FM:Usable sensitivity (75)(dBf): 9
* Station Preset(s) : FM18/AM12
* Tuner Frequency Range : FM:Tuner Frequency Range(MHz): 87.5-107.9, MW:Tuner Frequency Range(kHz): 530-1710
* Tuner Type : SSIR-EXA
* Volume Control : Tel/Nav Attenuation
Zvucnici :
-Alpine type E 10-ke 50 KM
Ostalo [/size]
-Alpine daljinski sa nosacem pase na sve osim DVD 40 KM kupljen prije 2 mjeseca
-Alpine kabl za iPod control 40 KM
-Aero Port 25 KM
-Kabl 50 kvadrata 5m sa osiguracem 100 KM 99.95% bakar
-4 vrste distribucije (dok ih poslikam)
-Kondenzator Hifonics potpuno nov u kutiji neraspakovan 100 KM
SLIKE USKORO SAMO DA SVE POSLIKAM , Sve potpuno ispravno , stanje navedeno slike originalne , sve info na PM i 062570111 Ammar
