Battery counter reset???
Cuo sam da ovo moze, ali ne znam kako. Ima li neko pametnu ideju kako da resetujem bateriju na TOSHIBA A300 laptopu???
i ja bih volio neki reset opaliti na svojoj bateriji (asus) pošto mi već par sedmica piše consider replacing your battery a ja mu kazem hell no :D
ibizasa je napisao(la):
Znam da postoji 100% ali ne znam kako se to radi
The Easy Way
Before we begin look at your battery and the casing directly surrounding it. If you see an inset button labeled “Reset” (like the ASUS A6403KM), and you are sure it is for the battery only, then you can use the method with a reset. If not, then use the directions without a reset.
Without The Reset
If your laptop battery does not have a reset button, then follow these steps:
1. Turn off all of your power saver settings on your laptop. This includes your sleep mode and any auto shut offs.
2. Use your laptop, do whatever you have to do, and run the battery down. Ignore any low battery messages.
3. Your laptop is going to die, so be sure that if you are doing anything mission critical save your work.
4. Plug it in and let it get a full charge without turning it on. Not even once. Not even to check your email really quickly.
With The Reset
If you have a reset button then try these steps:
1. Interrupt the battery recharge from step four above after about 1 hour.
2. Hold your power and reset button simultaneously for about a minute, your lights should flash.
3. Turn off the device as normal and finish the charge.
The Hard Way
The hard way is to get and run a piece of power manager software that will manage your battery reset.This is intended for those who repair and restore laptop batteries, or at least folks that can open their laptop battery's housing and identify and remove the "smart chip" inside.
Eeeeeeee :) ja svoj problem riješio, bio mi problem kako bih to nazvao 'konflikta' između biosa i win 7 pa sam se ponovno vratio na stari bios (prije update-a) i piči ko podmazano :D
A cek... sta su uradio u biosu
pa vid' prije 10ak dana sam skinuo sa asus support stranice (pošto mi je asus laptop) BIOS update tool i instalirao najnoviji BIOS za svoj laptop, sutradan mi se odmah javio problem sa baterijom, odnosno veliki X na njoj i poruka 'consider replacing your battery'
ignorisao sam problem et' do danas jer mi je laptop i dalje normalno radio dok je na bateriji al' mi je stalno javljalo tu poruku, nakon sto sam se odlucio da malo prosurfam, vidim cesto raja govori kako se ne uklapa bios s win7 i slično, pošto mi ne pada na pamet radit windows 7 update, samo sam otisao na asusovu support stranicu i skinuo bios koji sam ranije imao, pokrenuo program koji sam takodje nasao na njihovoj stranici, browse-ovao bios datoteku, opalio 'install' i to je to :D
poslije toga se comp resetovao i problem nestao :D
