The series engine of the Scirocco is very sporty. The series output rises to 370 hp and 519 Nm by optimizing the software, Downpipe and MR Car Design Stage Turbo kit 3. The backpressure optimized, manual welded, sport exhaust system from MR Car Design, made of steel and with TÜV certificate adds up to the optimal Power output and the muffled thunderous sound. MR Car Design installs furthermore the 35% fins limited slip differential - therewith the speed gets on the road without wheelspin. With these changes the DSG-Software has to be adjusted.
MR Car Design mounts a Stoptech high performance brake system with 4-pistons an two-pieces slotted discs size 355x32 mm. The brake system is completed with the inovative bleeding valve from Stahlbus.
New to the assortment are MR Car Design, 20" 1-part Emotion Wheels (Strada) aluminium rims. Hankook hoops the Scirocco with S1 EVO High performance tires (235/30 ZR20).
