USB stick podatci Help
Imam problem sa USB stickom i podatcima na istom...Uletio mi neki virus kad sam skenirao sa ESET-om obrisao mi malte ne sve podatke:icon_cry: Tu su mi mnogi bitni podatci i arhiva...Postoji li neki nacin da se vrate neki od podataka...Help please...
Skini program Handy Recovery v40 i ja mislim da ces uspjeti vratiti,bar sam ja vracao s njim sto je bilo izbrisano na USB,memory card itd.
Skinuo sam DDR - Pen Drive Recovery(Demo) pa nadje sve podatke ali ne mogu ih SAVE jer je demo :icon_cry: Sad cu probati sa ovim drugim programima...Hvala;)
roki_actros je napisao(la):
Izvoli: Pen Drive Recovery sa crackom( serialom) dakle puna verzija.
http://rapidshare.com/files/261882599/DDRPD_v3_SO_SA.rar
Power Data Recovery is a powerful data recovery software. It is one of the fastest and most effective programs of the data recovery software. Power Data Recovery is becoming the first choice when you need data recovery software to help you recover your lost data. Power Data Recovery is a read-only File Recovery Software and Data Recovery Software.
Power Data Recovery software could help you recover all your data no matter the data is lost by accidental deletion, format, re-partition, system crash or virus attack. Power data recovery is able to scan your device sector by sector to recover what ever left on your device.
Power Data Recovery provide deep scan module which can scan and analyze raw data format including Microsoft Office files, digital graphics/pictures, audio/video files. Please visit deep scan page for complete raw file format list.
Features:
Feature overview
* Recover data after accidental deletion
* Recover data after an accidental format
* Recover data from an inaccessible volume (logical drive)
* Recover data after FAT corruption
* Recover data after repartition (fdisk)
* Recover data from a crashed physical device
* Recover data after an MBR corruption
* Recover data from a hard disk drive, camera card, USB drive, Zip, floppy disk
* Recover data for any error except physical damage
Key Features:
* Supports FAT 12/16/32
* Supports NTFS
* Supports NTFS compressed and encrypted files
* Supports Dynamic Volume including Simple Volume, Spanned Volume, Stripe Volume, Mirror Volume and Raid Volume.
* Supports RAW data recovery
* Built-in preview function
* Built-in resume recovery function
* Built-in Recovery Wizard
Download links:
http://depositfiles.com/en/files/iu8q2tdww
http://uploading.com/files/3RTGYWPF/Power.Data.Recovery.4.11.Portable.rar.html
Probaj s tim, sretno ;)
Hvala, sad cu da probam...
BaXRS4 je napisao(la):
Ovo kad skinem Eset javlja da je zarazeno :icon_cry:
Ne obaziri se na to, to je radi keygena/cracka, i naravno izbrise ti odmah, iskljuci Eset, instalici, crackuj, pa ga onda opet ukljuci ;)
Evo ti moj program nekad mi je odradjivao posao http://www.mediafire.com/?sharekey=4dd6fba0e54c1d337f7ec40ada4772a6e04e75f6e8ebb871
ako to ne pomogne probaj s ovim;)
e Recover is a safe, affordable and easy-to-use file recovery solution, designed to recover and restore deleted files from hard drives, floppy drives and other types of fixed media. File Recover allows you to recover critically important documents, or other files, which have been lost by accidental deletion. These files may be lost by emptying the Recycle Bin, or using other deletion actions that bypass the Recycle Bin altogether. Such actions include Windows Shift-Delete, command line deletion, deleting excessively large files or using applications that delete files without the Recycle Bin. When a file is deleted from the Recycle Bin, or if the recycle bin is bypassed altogether, the file can no longer be recovered by the Windows Operating system. The content of the file still remains on the drive, relatively intact, until the section of the drive it occupies is overwritten by another file. File Recover identifies the contents of such lost files on the hard drive and allows you to recover them.If a file has been partially overwritten, File Recover attempts to reconstruct as much of the file as possible with the remaining contents. This allows you to salvage at least part, if not all, of that recovered file to continue using it as required.
File Recover feature highlights :
• Recovers files instantly from hard drives, floppy drives and other types of fixed media. If you are a home user or a network administrator, File Recover fills a critical gap in your data protection strategy.
• Rapid scan engine - a typical hard drive can be scanned for recoverable files within minutes.
• Scan all files and directories on selected hard drives.
• Search for a recoverable file using part or all of its file name.
• Utilizing a non-destructive, read-only file recovery approach. File Recover will not write or make changes to the section of the drive from which it is recovering data.
• Batch file recovery (recovers multiple files in one action).
• Works around bad-sector disk areas. Recovers data where other programs fail.
• Supports standard IDE/ATA/SCSI hard drives, including drives larger than 8 GB.
• Supports hard drives formatted with Windows FAT16, FAT32 and NTFS file systems.
Designed for Windows® 2000, XP Pro, XP Home, Vista Basic and Vista Ultimate
Kod:
http://rapidshare.com/files/259595738/File.Recover.7.5.rar
I mislim da se kaže podaci a ne podatci:icon_question:
Hvala svima koji su se ukljucili u rjesenje problema...Uspio sam rijesiti isti uz pomoc Pen Drive Recovery zahvaljujuci BaXRS4 koji je postavio link...Imate svi + za help ;) Uspio sam 99% podataka vratiti...
Nek si povratio doc to je vazno !:cool:
