Evo koja priča zanimljiva da se ima šta čitati i iz svijeta .. :icon_smile:
You always remember a first love. Whether it be a song, a car, or a person, the memories last long after the love has faded. In the case of Tom from Bangkok, Thailand, his first automotive love came in the form of a 240SX. Having worked hard, he saved up until he was able to purchase the car at the age of 15, after moving to the United States with his family. But like most first loves, this one didn’t last, and after 5 years of ownership, he sold the 240SX and purchased a 350Z. Don’t worry, it only gets better from here.
After a year of modding the 350Z, Tom sold his car to his brother and moved back to Thailand. With the memory of the 240SX still fresh in his mind, he started the search for a clean S13, and after a year and a half of hunting, Tom found the perfect car, a bone-stock S13 equipped with a CA18DET and an automatic transmission. After racking up some kilometers, the transmission faltered and Tom decided it was time for an SR20DET swap, and the perfect specimen you see here was born.
One of the reasons Tom loves the S-chassis is the relative ease of finding new and used parts, and what a list of parts it is! A JDM fanboy myself, looking over his mod list is like reading the menu at a great restaurant; everything looks amazing! Having decided to go all out with his build, Tom’s order sheets read like a who’s who of JDM goodness: Tomei, Nismo, Greddy, Blitz, Vertex, Work; the list goes on and on.
Having owned a 240SX previously, Tom knew exactly what he wanted and what he didn’t. Originally intending to keep the interior stock, he scrapped that plan in favor of a full interior makeover. A set of rare Autech seats sourced from an S15 hold Tom in place while a Maziora steering wheel mated to a Works Bell hub and quick release accept his driving input. A Greddy turbo timer and Profec boost controller keep the turbo running optimally, while Defi BF gauges and a Tomei gauge cluster keep Tom apprised of the car’s vital signs. A Tomei shift knob, Yashio Factory spinner knob, Origin carbon fiber door panels, and a JDM S13 CD-holder armrest round out the interior modifications.
Wrestling with his color choices for a month, Tom made the perfect choice when he selected the metallic purple you see here. But before the paint was laid down, the body had to be shaped. A full Vertex body kit was embellished with Origin 20mm front and 50mm rear over-fenders. Aerocatch hood latches keep the D-Max hood in place, and an Origin roof wing, East Bear mirrors, and GT-R grille add to the flair. After 3 months of paint and body work, the exterior overhaul continued with Silvia brick headlights, Origin taillights, Circuit Sports clear corner lights, Circuit Sports position lights, and JDM S13 window visors. To button up the look of the car, Tom added the perfect contrast to the sparkly purple paint: fully polished, aggressive Work Equips, 18×10-10 in the front and 18×11.5-10 in the rear. The Equips are covered in 225/35/18 and 265/35/18 rubber, and bolted to the car with Kics Project neo-chrome lug nuts.
http://www.stancenation.com/wp-content/uploads/2013/05/slammed-fitted-nissan-silvia-s13-flushstyle-16.jpg
http://www.stancenation.com/wp-content/uploads/2013/05/slammed-fitted-nissan-silvia-s13-flushstyle-14.jpg
In order to mount the timeless Work Equips, Tom first converted the S13 to a 5-lug setup, which also allowed him to upgrade the brakes to Infiniti Q45 front calipers and Nissan Z32 rear calipers with Project Mu lines. To dial in the ride height, Tom added Tein Super Drift coilovers, Cusco rear upper control arms, Cusco rear toe arms, Powered by Max Pro front and rear lower control arms, and Kazama hard tie rods and tie rod ends. Determined to prevent even a hint of body roll or flex, Tom then proceeded to add more bars and plates than a maximum security prison. A Cusco 6-point roll cage with the diagonal add-on bar, Cusco rear strut tri bar, and Carbing front strut bar pull double duty, looking great while solidifying the chassis. Do Luck provided the floor bar, chassis support bar, and front ladder bar, and the C-pillar bar is a rare piece from Rash Facture. Still not satisfied with his car’s stiffness, Tom purchased a Uras frame rail brace, a Nismo Power Brace, Sunline front tie brace, Nagisa Shakitto plate and fender brace, Energy subframe bushing, and KTS rear subframe brace and tie brace.
http://www.stancenation.com/wp-content/uploads/2013/05/slammed-fitted-nissan-silvia-s13-flushstyle-12.jpg
http://www.stancenation.com/wp-content/uploads/2013/05/slammed-fitted-nissan-silvia-s13-flushstyle-8.jpg
With the SR20 swap under the hood, Tom turned his attention to the motor. An S13.4 hybrid valve cover keeps the BC valve springs and retainers, Super Tech valve stems, Tomei poncams, cam gears, and rocker arm stoppers under wraps. Tomei also supplied the exhaust manifold, turbo elbow, 1.2 mm head gasket, regulator, fuel pressure gauge, oil pan, and oil cap to the engine. The upgraded turbo is a GT-RS unit from HKS, which works in harmony with an HKS GT actuator, SSQV blow off valve, and intake filter, and a Greddy intake manifold. Fuel is controlled by a Walbro fuel pump and Nismo 555cc injectors. To keep the motor cool under pressure, Tom added a Greddy radiator, oil cooler and oil filter, a Blitz intercooler, Billion power steering reservoir, and Yashio Factory radiator hose and water pump pulley. On the exhaust side, an RSR downpipe feeds into a Dart Izumi dual catback exhaust. Tom also installed a Carbing radiator cooling panel and relocated the battery. The result is an impressive 384 hp at 1.4 bar from the SR20 red top.
http://www.stancenation.com/wp-content/uploads/2013/05/slammed-fitted-nissan-silvia-s13-flushstyle-3.jpg
Tom’s ownership of his 240SX may not have stood the test of time, but like most of us, he learned a great deal from those 5 years spent with his first love. Determined to make his second go-around with the S-chassis a success, he spent a year and a half re-imagining his S13, and a masterpiece was born. Bravo, Tom! Bravo!
http://www.stancenation.com/wp-content/uploads/2013/05/slammed-fitted-nissan-silvia-s13-flushstyle-6.jpg
http://www.stancenation.com/wp-content/uploads/2013/05/slammed-fitted-nissan-silvia-s13-flushstyle-11.jpg
http://www.stancenation.com/wp-content/uploads/2013/05/slammed-fitted-nissan-silvia-s13-flushstyle-2.jpg
Wheels/Tires/Suspension
Work equip 18×10 -10, 18×11.5 -10
225/35/18, 265/35/18
Kics neo chrome lug nuts
5 lugs swap
Tein super drift 10k /8k
Power by max pro front lower control arm
Power by max pro rear lower control arms
Doluck floor bar
Doluck front ladder bar
Doluck chassis support bar
Nismo power brace
Nagisa shakitto plate
Nagisa fender brace
Cusco rear tri strut bar
Cusco 6point roll cage
Cusco diagonal add on bar
Cusco Rucas
Cusco rear toe rods
KTS rear tie brace
Kazama tie rod ends
Rash facture C pillar bar
Nismo 2way LSD
Q45 front calipers, r32 rear calipers
Project mu brake lines
Exterior
Vertex body kit
Origin over fenders 20mm/50mm
Origin roof wing
Origin taillight
Dmax Hood
Aero catch hood latch
Bricks head light
Circuit sport clear corner lights
Circuit sport position light
Gtr grill
S13 jdm window visors
East bear side mirrors
Interior
Defi BF gauges
Greddy new profec boost controller
Greddy turbo timer
Origin carbon door panels
S15 Auctech front seats
Works Bell quick release
Works bell hub
JDM Maziora steering wheels
Tomei shift knob
Tomei jdm cluster
Yashio factory spin knob
S13 JDM CD keeper armrest
Engine
Sr20det redtop (384hp at 1.4 bar)
Hybrid S13.4 valve cover
Super tech valve stems
HKS F con V Pro 3.0
HKS GT-RS
HKS GT actuator
HKS intake filter
HKS ssqv blow off valve
HKS twin plates clutch
Tomei exhaust manifold
Tomei turbo elbow
Tomei poncam
Tomei camgears
Tomei rocker arms stopper
Tomei 1.2 head gasket
Tomei regulator
Tomei fuel press guage
Tomei short shifter
Tomei oil cap
Tomei oil pan
Nismo 555cc
Walbro fuel pump
Greddy radiator
Greddy oil cooler
Greddy oil filter
Blitz intercooler
Billion power steering tank
Yashio factory water pump pulley
Yashio factory radiator hose
Carbing cooling panel
Skid plates
Rsr down pipe
Battery relocation
Dash battery box
Ee raja , ako ste za ... Da prevodim ubuduće ove članke , jer raja koja ne zna baš engleski da može razumjeti o čemu se priča ... Ako ste za , samo recite
5 lugs swap
Doluck floor bar
Nismo power brace
Nagisa fender brace
Cusco Rucas
Cusco rear toe rods
KTS rear tie brace
Kazama tie rod ends
Nismo 2way LSD
Exterior
Vertex body kit
Origin roof wing
Origin taillight
Dmax Hood
Bricks head light
Gtr grill
Interior
Defi BF gauges
Greddy turbo timer
Works bell hub
Tomei shift knob
Tomei jdm cluster
Engine
HKS F con V Pro 3.0
HKS GT-RS
HKS GT actuator
HKS intake filter
Tomei turbo elbow
Tomei poncam
Tomei camgears
Tomei regulator
Tomei short shifter
Tomei oil cap
Tomei oil pan
Nismo 555cc
Walbro fuel pump
Greddy radiator
Greddy oil cooler
Greddy oil filter
Blitz intercooler
Skid plates
Rsr down pipe
Battery relocation
Dash battery box
