[attachment=19207]
Product selling point:
>Small size of transmission camera hides into a normal working pen
> Built-in antenna
>Small palm size of receiver DVR for mobile usage
>Video Format: Mpeg-4,AVI (640 or 320 @ 30fps) MP3,Wav
>Memory Support: SD: 1GB to 4GB./ Usb-Disk storage up to 20GB
>2.5" LCD screen with 882 × 228 resolutions
>Rechargeable Li-battery in receiver DVR enable at least 2.5 hours continuous working
>380TV lines clear picture display
>4-channel available to avoid interference
>Built-in microphone in camera and speaker in receiver
>Min. 50m transmission distance without blocks
Parameter list:
Item
Value
Transmission Frequency
ISM 2,400MHz~ 2,483MHz 4CH*
Modulation Mode
FM
Antenna Type
Hidden
Unobstructed Effective Range
50m(Without Block)
Operating Temperature
0℃~ +50℃ / +14℉~ +122℉
Storage Temperature
-20℃ ~ +60℃ / -4℉ ~ +140℉
Operating Humidity
85%RH
CAMERA
ISM 2,400MHz~ 2,483MHz CH1*
Imaging Sensor Type
CMOS
CMOS Total Pixels
510×492(NTSC)
Horizontal Resolution
380 TV Lines
View Angle
62°
Minimum Illumination
3.0 Lux / F1.5
Transmission Power
10mW
Power Supply
DC 5V 95mA
Battery Performance
Li-ion Battery
Battery Capacityl
130 mAh
Charge time
30 minutes
Working Time
1 hour
Dimensions( LX D)
148mm*15.4mm
Weight
33g
RECEIVER
Receiving Sensitivity
≤-85dBm
LCD Type
TFT
LCD Screen Size
2.5"
Resolution
882 × 228
Active Area
49.2mm×38.142mm
Dot Pitch
0.055mm×0.163mm
View Angle(U/D/L/R)
10°/ 30°/ 45°/ 45°(Min.)
Brightness
250 cd/m3
Contrast Ratio
300:1
Resolution
640*480 / 320*240
Compressed video format
MPEG-AVI 30pfs
Speaker
1W
Flash memory
64M
Storage media
SD/MMC (1GB to 4GB)
Internal battery
Li-ion battery 2500Mah
Working Time
2.5hour
Power Supply
DC 5V 1A
Vided Output level
1Vp-p@75ohm
Audio Output level
1Vp-p@10KΩ
Weight
180g
Dimensions (WxDxH)
70mm×120mm×24mm
Solar charger
Power Source
DC 5V 200mA
Power output
DC 5V 200mA
Li-battery
1350MAH
Dimensions (WxDxH)
43mm×98mm×13mm
Weight
66g
* Channel Frequency: CH1=2414MHz;CH2=2432MHz;CH3=2450MHz;CH4=2468MHz
300 Ojra
Bubica sa bluetooth reciverom (radi na sve mobitele koji imaju bluetooth konekciju)
190 ojra
ako se uzima i kamera i bubica zajedno onda je cijena 460 ojra
