Sema instalacije auto ozvucenja sa dva pojacala!
meni je bilo od pomoci..nadam se da ce nekome posluziti.
Treba tu malo i objasnjenja koji presjek naponskog kabela na dva pojacala, ovako ce strucnjaci vidjeti shemu i na kabel od 10 kvadrata nakaciti oba pojacala :D
ISO KONEKTOR ;)
Pinout
| A | B | | I | J |
| C | D | | K | L |
| E | F | | M | N |
| G | H | | O | P |
Pin Color..............Description
A Purple..............Back Right Speaker +
B Purple/Black......Back Right Speaker -
C Grey................Front Right Speaker +
D Grey/Black........Front Right Speaker -
E Vit...................Front Left Speaker +
F Vit/Black...........Front Left Speaker -
G Green...............Back Left Speaker +
H Green/Black.......Back Left Speaker -
Pin Color Description
I
J Brown Mobile phone system
K
L Yellow Constant 12V
M Blue/White Remote start (12V for start of amplifiers etc)
N Orange/White Illumination
O Red Ignition 12V
P Black Ground
DEBLJINA/ DUŽINA/ AMPERAŽA NAPONSKIH KABLOVA
Recommended Cable Size by Power and Distance
Total RMS
Power (watts) Distance
4 feet 8 feet 12 feet 16 feet 20 feet
100 10 gauge 10 gauge 8 gauge 8 gauge 4 gauge
200 10 gauge 8 gauge 8 gauge 4 gauge 4 gauge
400 8 gauge 8 gauge 4 gauge 4 gauge 4 gauge
600 8 gauge 4 gauge 4 gauge 4 gauge 4 gauge
800 4 gauge 4 gauge 4 gauge 2 gauge 2 gauge
1000 4 gauge 4 gauge 2 gauge 2 gauge 2 gauge
1400 4 gauge 2 gauge 2 gauge 2 gauge 2 gauge
Current Draw by Power
Total RMS
Power (watts) Current
Amps
100 16
200 32
400 64
600 96
800 128
1000 160
1200 172
1400 188
Power & Ground Cable Specs
Cable Size
Wire Gauge Current Capacity
Amperage (amps)
1/0 350
2 225
4 150
8 100
10 60
12 40
14 25
16 15
SPAJANJE SUBOVA - OMAŽA
2+2ohma = 4 \
2+2ohma = 4 / 2/8 ohma
2+2ohma = 1 \
2+2ohma = 1 / 0,5/2 ohma
4+4ohma = 2 \
4+4ohma = 2 / 4 ohm
4+4ohma = 2 \
4+4ohma = 2 / 1 ohm
PODEŠAVANJE FREKVENCIJE NA POJAČALU, NISKE (SUB), VISOKE ( OSTALI ZVUČNICI) i KOMBINACIJA (AKO IMATE KICK)
HPF - High pass filter - visokopropusni filter - propušta iznad određene frekvencije
LPF - Low pass filter - niskopropusni filter - propušta ispod određene frekvencije
BPF - bandpass filter je kombinacija LPFa i HPFa.
Subsonic je HPF samo za vrlo male frekvencije, reda npr. 10-50 Hz, kad npr. želimo spriječiti woofer da svira neke najniže tonove ( puno snage i velika ekskurzija ).
Tweeteri obično sviraju od nekih 2.5-3kHz ( 3.5-4.5kHz najčešće )
Srednjetonci od 200-300 Hz ( 500 Hz najčešće ) do nekih 4-5kHz.
13cm idu od nekih 60-70 Hz do 3-4kHz
16cm idu nešto dublje.
itd...
Ovako da objasnim malo.
Povezivanje struje
1. crveni kabal sto ide iz akomulatora je "+"
2. crveni kabal krece od akomulatora,prolazi kroz kondenzator pa se spaja sa pajacalom
3. kad krene crveni kabal(+) ka pojacalu spaja se prvo sa osiguracem od 60A pa de ka kondenzatoru
4. spajanje se sa kondenzatorom:
- crveni kabal(+) ide na (+) od kondenzatora
- na plus od kondenzatora se stavljaju jos dva (+) kabla koja idu ka jednom i drugom pojacalu
- minus (-) od kond. je masa i ona ide na karoseriju od auta
*kondenzator mora da bude jacine preko 1.5 F (farad)
5. jedan od (+) kablova koji smo stavili na kond. se svaja na jedno pojacalo,a drugi(+) na drugo
6. minus od pojacala je masa i ona se spaja na karoseriju od auta
Povezivanja radija i pojacala
1. u radio se spaja kablovi front [ L ] i [ R ] i frear [ L ] i [ R ]
2. ti kablovi idu u prvo pojacalo u [ line in ] istim redosledom
3. spajanje prvog i drugog pojacala
- od prvog izlaze kablovi iz [ line out ]
- ti kablovi ulaze u drugo pojacalo gde pise [ line in ]
Spajanje zvucnika sa pojacalom (1 i 2)
-Prvo pojacalo (4 kanalno)
standardno spajanje zvucnika i pojacala
-Front R i L
-Rear R i L
-Drugo pojacalo (4 kanalno) za subwoofer
1. u dva kanala spajamo jedan woofer
-od prvog kanala izkoristimo (+) a od drugog kanala (-) za spajanje jedog zvucnika
2. drugi zvucnik
- od treceg kanala izgoristimo (+) a od cetvrtog (-) za spajanje drugog zvucnika
I to je od u principu...ako ima neko nekih pitanja neka pita..;)
*kondenzator mora da bude jacine preko 1.5 F (farad) on ti i ne treba i ako imaš ne mora biti jači od 1.5 F, a i rijetko koji ozbiljniji dB fan koristi kond. meni je to više furka i ICE, diode ovo ono :D Dobro je objašnjenje, osnova svaka čast ;)
Nije mi se dalo citata sve detaljno ali ima tu nekih ispravki.... Na prvi pogled sto sam primjetio kondezator ne treba samo jedno ukrasno smijece koje zna da ti povuce struje vise nego sto treba iz aku znaci samo sminka u autu.... A ako vec ides na njega pravilo je 1 F = 1kw rms a peak power zaboravite.... Dalje presjek kabla i osiguraca takodje se gleda snaga samog Ampa..... I ako vec pojacala stavljas u link ne mogu dva razlicta pojacala moraju biti dva ista uskladjena za to LINK :D Primjera radi ja sam linko dva digital desings Z1 brutalno je ;) Svako dobro
