Jedan sub popravljan od strucne strane AudioPower NS. (uvoznik GZ Opreme)
Drugi radio ukupno nekih 2 sata
Rade bez greske, moze se poslusati
spec. sub.
Diameter: 30 cm / 12"
Power handling: 1000 WRMS
Impedance: 2 x 2 Ohm
Voice coil: 63 mm / 2.5"
Excursion: X max. 20 mm / 0.8"
Resonance Frequency: FS 33 Hz
SPL 2.83 V/m: 92 dB
http://www.ground-zero-audio.com/english/05_rw30spl.htm
Kutija nekih 110L + port 16-ka + 2 x sub-a = 450KM
Moguca zamjena za sub 15-ku da je Impendance ispod DVC 2Ohm uz moju doplatu
spec. sub.
SPL 2.83 V/m: 92 dB
