Zbog prosirenja porodice primoran sam da se oprostim od mojih ''bebica'' :icon_biggrin:
Dakle, rec je o pojacalima Phase Evolution Opus, top modelima ovog proizvodjaca.
Prvo pojacalo je 4kanalac, Phase Evolution Opus 150.4
Specification:
RMS Power Output (DIN 45 324) 4 Ohms, 13.8V: 4 x 170, 2 x 500 watts
RMS Power Output (DIN 45 324) 2 Ohms, 13.8V: 4 x 240, 2 x 525 watts
RMS Power Output (DIN 45 324) 1 Ohms, 13.8V: 4 x 250 watts
Frequency range: 5 Hz - 50 kHz (-3 dB)
Distortion factor: <0.05%
Input sensitivity RCA: 0.25 - 5V / 20 kOhms
S/N ratio (IEC A): > 100 dB
Power supply (IEC581): + 12V negative ground
Dimensions (W x H x D): 526 x 54 x 259 mm
Variable bandpass crossovers:
Low pass filter 40 - 600 Hz, 12 dB per octave
High pass filter 50 - 500 Hz, 12 dB per octave
Variable subsonic filter 10 - 40 Hz, 24 dB per octave
Low level pass through RCA jacks (channel 1 and 2 only)
Weight 8.9 Kg
Evo i link testa
http://www.hificar.cz/download/test_2005.pdf
Znaci, mrcina od 4x170W !!!!!!! RMS-a na 4 ohma, odlican zvuk, razne skretnice, ventilator...
Dakle pojacalo je u EXTRA stanju, nikad otvarano, popravljano... i sl.
Cena, 330eur
Drugo pojacalo je monoblock, Phase Evolution Opus 500.1
RMS Power Output (DIN 45 324) 4 Ohm, 13,8 V: 1 x 550 Watt
RMS Power Output (DIN 45 324) 2 Ohm, 13,8 V: 1 x 825 Watt
RMS Powre Output (DIN 45 324) 1 Ohm, 13,8 V: 1 x 1100 Watt
Frequency range: 5 – 600 Hz (-3 dB)
Distortion factor: < 0,1 %
S/N ratio (IEC A): : > 100 dB
Input sensitivity RCA: 0.25 – 5 V / 20 kOhm
Dimensions (W x H x D): 406 x 54 x 259 mm
Weight 6,9 Kg
Cena, 250eur
A evo i koliko su kostali novi
http://www.md-elektronika.hr/Caraudio/ostalo/phase_car_cjenik.xls
Par slika iz mog duplog poda (gore 4kanalac, dole monoblock), a ako kome treba mogu ga detaljnije poslikati
Sav dodatan info na PM
Specification:
Weight 8.9 Kg
Evo i link testa
Cena, 330eur
Weight 6,9 Kg
Cena, 250eur
