Prodajem pojacalo Lightning audio B300.4
•2-, 3-, or 4-channel output
•Tri-way capable (Tri-Way crossover required)
•150 watts x 2 in bridged mode
•50 watts x 4 into 4 ohms
•75 watts x 4 into 2 ohms
•requires 4-gauge power and ground leads — wiring and hardware not included with amplifier
•preamp outputs
•front/rear selectable 40-400 Hz variable high-pass/low-pass crossover, 12 dB/octave
•12 dB bass boost at 50 Hz
•speaker-level inputs
•13-7/8"W x 2-1/4"H x 11-1/8"D
Sliku trenutno nemam, nije aparat kod mene
Slika je s neta, pojacalo je isto, samo nema natpis bolt
Cijena 80 km
•preamp outputs
Cijena 80 km
