Pojačala su u OK stanju, nisu popravljana, imaju ambalažu... jedno ima remote
Za slušanje rade na 0.5, bez problema, brp na 0.25...
Ja sam im izmjerio u linku 2,8kw na 1 ohma realnog otpora :respect:, po nekim testovima bi trebalo imat 1.6kW-1.9kW svaki
Sa jednom tridesetkom i jednim NSB90, 149.6 u golfu...al mislim da bi išlo još dosta gore :respect:
Prodajem radi promjene planova
Specifications
Input Sensitivity
0.2V - 8V
Variable High Pass Filter
Subsonic Filter
10 Hz - 50 Hz at 24 dB/Oct
Variable Low Pass Filter
20 Hz - 200 Hz at 24dB/Oct
Clipping Display
LED
Tested Voltage
14.4V
Tested THD
1%
Cont Power at 4 ohm
300W x 1ch
Cont Power at 2 ohm
Damping Factor
>250 @ 1 ohm
Cont Power at 1 ohm
1200W x 1ch
Cont Power at 4 ohm Mono
300W x 1ch
Cont Power at 3 ohm Mono
Dynamic Power
2300W x 1ch
Efficiency thru Output
>75%
Dimensions - mm
300 L x 235 W x 53.4 H
Signal to Noise
85 dB
Shipping Weight
12 lbs (5.443Kg)
Slike:
Cijena: Za dva komada 500€, a za komad 270€
Zamjene za RF t3002, t5002, t5001, t10001, t20001.... i svašta drugo ako je dobra ponuda :respect:
Specifications
Input Sensitivity
0.2V - 8V
Subsonic Filter
Clipping Display
LED
Tested Voltage
14.4V
Tested THD
1%
Cont Power at 4 ohm
300W x 1ch
Cont Power at 2 ohm
Damping Factor
>250 @ 1 ohm
Cont Power at 1 ohm
1200W x 1ch
300W x 1ch
Dynamic Power
2300W x 1ch
>75%
Dimensions - mm
Signal to Noise
85 dB
Shipping Weight
12 lbs (5.443Kg)
Slike:
