Na prodaju je komplet muzika marke audio system .
Muzika se sastoji od :
Pojacalo Audio system F4-600 cetverokanalno (http://www.audio-system.de/alte-serien_twister-f4.php )
4x 150 Watt RMS @ 4 Ohm Stereo
2x 460 Watt RMS @ 4 Ohm Mono
4x 230 Watt RMS @ 2 Ohm Stereo
2x 595 Watt RMS @ 2 Ohm Mono
Pojacalo Audio System F2-500 dvokanalno (http://www.audio-system.de/alte-serien_twister-f2.php )
2x 230 Watt RMS @ 4 Ohm Stereo
1x 800 Watt RMS @ 4 Ohm Mono
2x 400 Watt RMS @ 2 Ohm Stereo
1x 1180 Watt RMS @ 2 Ohm Mono
Dva woofera Audio sestem X ion 12" (http://www.audio-system.de/alte-serien_x--ion-line.php )
12 INCH LONG-STROKE SUBWOOFER
2x 600/400 Watt. 3” double voice coil. Impedance 2x 4 Ohm.
Double spider, sow surrounding/membrane.
A new compound membrane from glass fibre and paper.
Installation depth: 158mm
Installation diameter: 283mm
Outside diameter: 312mm · Weight: 11 kg
Kondenzator,kutija originalna pravljena za ova dva woofera s prednje strane plexiglas osvjetljeno unutra plavim svjetlom koje se moze spojiti npr kao sto je u mene spojeno sa svjetlom kada se otvori gepek.. Cijena 615 km.
Prodajem ili mijenjam ponudite sta imate pa mozemo pregovarati ....slike uskoro ce biti ....
