Block
Z1 Stage 2 longblock
Oversized Wiseco Forged Coated Pistons with New Rings
Eagle Performance Connecting Rods
ARP Connecting Rod Bolts
Rotating Assembly Balanced
Block Decked
Cylinders Bored (3.1)
Coolant Galley Casting Flash Removed
300zx Convertible Engine Mounts
Heads
Camshaft Journals Polished
Heads Surfaced, Pressure Tested
New Valve-Stem Seals
Port-work, Intake & Exhaust Runners Opened Up & Smoothed Out
14-Angle Radius Cut Valve Job Including Bowl Work
De-Shrouding of Intake and Exhaust Valves
Z1 HL-14 Camshafts 270 dur/.374 lift
Nismo Performance Valve Springs
Bronze Valve Guides
Induction and Cooling
Z1 GT675RS Turbo kit
Z1 Upgraded Side-Mount Intercoolers
Z1 Intake Hard-Pipe
”DOOLZ” Dual Intake + 2 JWT Pop Chargers
Turbo XS RFL BOVs
Extruded and Honed Plenums
Ported Throttle Bodies
Z-1 Lower Radiator Hard Pipe
Howe Performance TT Radiator
P.E. High Pressure Cap
T-Bolt Clamp Kit
Fueling and Electronics
Nismo 740cc Injectors
Twin Turbo Fuel Pump
Apexi AVCR Boost Controller
Greddy Turbo Timer
Z1 EPROM Upgrade
Tien EDFC Controler
Exhaust and Drivetrain
2.5" Z1 5-Bolt Split Down-Pipes
2.5" Z1 Test-Pipes
JWT Genie Cat-back Exhaust System
RPS Carbon Carbon Clutch and Flywheel
New 97' J-Spec Tranny
Steel Braided Clutch Line
Z-1 One Piece Drive Shaft
Suspension
Tien Flex Type Coilovers
Powertrix Upper Adjustable Arms Front and Rear
Powertrix Adjustable Tention Rods
Stillen Sway Bars Front and Rear
