evo sta se treba programirat da bi se rijesio problem dayline farova znal ovo ko da uradi?
Vag Com from Ross-Tech is needed to re program the lights and program the intensity to 112%.
the car's cpu shuts them off, because it thinks the bulb has burned out (to low resistance because of the leds used) you can fix this by placing a resistance paralel over the leds (warning: resistor gets hot) or an normal lightbulb between the + and - of the leds.
