ITALY je napisao(la):nemoj to sam raditi, postoji na netu metoda da pomocu usb kabla ucitas novi softver na telefon, upalio bi mobitel, ali problem je sto nebi imao signala. IMEI(neka skracenica...) bi ti se promjenio i morao bi dati 3 puta vise para za popravak nego da ga u tom stanju nosis u servis. Ja sam za LGkg990u umjesto 15km, platio 70km popravku zato sto sam htjeo da budem sam svoj majstor
Potpis, meni se takodjer desilo na istom modelu davno, potrebno nanovo fleshovanje i novi sw i radit ce k'o sat...Jassmin je napisao(la):Dešava se svakome nakon određenog perioda korištenja, software, 20ak KM i to je to.
First of all ,
Things you need
XS++
Main Firmware & Filesystem(Password = kkan) - (The Latest Main firmware+Filesystem | R8BA024 )(There Is a VKP File in The zip (this vkp is to unlock your flashed k810i later on if you want to keep the vkp you can!) , if not just delete that ...no need of that
1>CONNECTIONG THE PHONE
Install The Phone XS++ & Connect The Phone (start turn the phone off remove the memory card and take out the battery for a few seconds ... then replace the battery and connect your USB CABLE first to the phone whilst holding the "C" key down then connect it to your USB PORT (still holding the "C" key!))
2>Flashing MAIN FIRMWARE + FILE SYSTEM & CUSTOMIZATION
>Select the downloaded main firmware & filesystem
>select customize filesystem
Model = k800
Select CDA & Region = EUROPE_2(CDA102511/2)
>Set the options as above & Hit FLASH
##This selection is only for the files i hav mentioned above(R8BA024 - MAIN FIRMWARE + FILESYSTEM)##
After all these processes you will get a massage = Disconnected,Unplug Your Phone
>Then Unplug Your Phone ,Remove the battery & reinsert it .Then Turn On The Phone ....
Now U hav Ur new k810i )
Zoro je napisao(la):K800i da bi flesao tj da bi popravio red blink problem potreban je alat koji se zove setool... U zadnjih godinu dana ti aparati DB2020 a i prije toga se otkljucavaju na patch metodu i potrebno je svaki put posle ucitavanja softvera otkljucati ga ponovo...
Uglavnom, ukoliko je tel bio otklucan na patch dzaba ti ovaj tutorijal i to kada ce ti posle bit locked i pod uslovom da ga podignes sa ovim. Isto tako vrsiti update preko servera SE mozes samo na ispravnom telefonu koji pali. Tako da i to otpada.
Software od K810i i od K800 je identican tako da se ne smaras sa tim razlike su zanemarljive
Mani se toga i nosi u servis kod mene je popravka tako necega 15 km i odmah uradim dok si tu nema ostavi dan dva.
Jos ti imas srecu sto je to kod tebe mali problem koji je lako resiv.
