muha je napisao(la):
koji su ti woofer i jel amp stabilan na 1 Ohm?
Rijec je o monobloku odnosno kenwoodovoj D klasi, sad bi muha rekao smece-sonic, ali nije bas tako, amp je dobar skroz, stabilan je na 1ohm imao sam takvog istog pa sam ga prodao, pa sam opet uzeo isto...
dva izlaza samo radi lakseg spajanja 2 suba, D klasa se se nemoze bridzovati kako ja znam...
Kako god spojis jedan sub na njega dobro si spojio, bitno je samo + sa amp-a na + suba i - sa amp-a na - suba...
Key Features:
D-class Amplifier Circuit
1Ω Load Capability
Dual Mono Drive (Two Amp Bridged Connection, 2-4ohms)
500W @ 4ohm
900W @ 1ohm
Amplifier Features:
Class D Amplifier Yes
Load Capability 1Ω Stable
Maximum Output Power 1800W
Rated Power Output 500W x 1 (4Ω)
Rated Power Output 900W x 1 (1Ω)
Low-pass Filter Yes
Bass Boost Circuit Yes
Infrasonic filter Yes
Phase inverter 0°(Normal) / 180°(Reverse) Yes
Dual Mono Drive Capability Yes
Power Indicator Multifunctional
Line in 1 RCA (Gold Plated)
Line out 1 RCA (Gold Plated)
Speaker level Input Yes
Removable Coverplate Yes
Yes
DC cable Supplied No
Amplifier-Specifications:
Maximum Power Output (4Ω) 1800W x 1
Rated Power Output (4Ω, 14,4V) 500W x 1 (20Hz ~ 200Hz, 0.5%THD)
Rated Power Output (2Ω, 14,4V) 900W x 1 (100Hz, 0.9%THD)
Rated Power Output (1Ω, 14,4V) 900W x 1 (100Hz, 1%THD)
Low-pass Filter 50~200Hz (24dB/oct)(B-Channel)
Bass Boost Circuit 0~18dB/oct
Bass Boost Frequency 40Hz ~ 100Hz (Variable)
Infrasonic filter 15/25Hz (18dB/oct)
Input Sensitivity 0.2 ~ 5V
Input Impedance 10kΩ
Signal to Noise Ratio 96dB
Frequency response (+0dB, -3dB) 5Hz ~ 200Hz
Operating voltage 14.4V (11V ~ 16V allowable)
Maximum current consumption 60A
Installation Size (WxHxD) 380 x 61 x 286 (mm)
Weight 5.8kg
Evo i Instruction manual:
http://images.kenwood.eu/files/prod/29/5/KAC-9152D_9102D_8152D_8102D_(EN).pdf
Pozzzzzzzzzzz
