Holden EFIJY Hot Rod Concept
Dimensions
· Length: 5162mm Width: 1999mm
· Height – drive setting: 1386mm Height – show setting: 1274mm
· Ground clearance - drive: 139mm Ground clearance - show: 27mm
· Track front: 1640mm Track rear: 1660mm
· Wheelbase: 2946mm
Powertrain
· Engine: GM 6.0-litre, LS2 aluminium V8 with Roots-type supercharger
· Bore and stroke: 101.6 mm x 92.0 mm
· Compression ratio: 10.9:1
· Power and torque: 480kW (645 bhp) @ 6400 rpm
· Torque: 775Nm (560 ft/lb) @ 4200 rpm
Dimensions
· Wheelbase: 2946mm
Powertrain
