Da nazalost to sto se koristi na db drag krece sa cijenom od 400$ pa na gore al evo ti par opcija:
1. Najednostavnija, Digia SoundMonitor + Nokia ili Samsung (S60v2)
Program koristi mikrofon tel i prikazuje db, nije bas najtacniji ali za tvog eksperimentisanja moze posluziti.
Skinuti mozes ovdje:
Kod:
http://rapidshare.com/files/83171420/Digia.SoundMonitor.v1.02.S60.SymbianOS7.Cracked-BiNPDA.zip
2. Malo komplikovanija, Pocket RTA v1.3 + Pocket PC ili telefon sa Windows Mobile
Features:
* 44Khz sampling allowing signals up to 22Khz to be measured.
* Dual Channel FFT display (PC version only).
* Definable FFT size and sample frequency (Pocket PC only).
* Single channel spectrograph
* Standard ANSI/IEC A and C weighting curves.
* Automatic noise cancellation.
* Automatic peak note / frequency and octave display.
* Narrow band Linear and Logarithmic scalable displays.
* Octave, 1/3 octave and 1/6 octave displays.
* SPL (Sound Pressure Level) display.
* 250x zoom for accurate analysis of narrow band data.
* Internal Signal Generator
* Touch screen plotting of nearest point with frequency and decibel readout.
* Up to 64x averaging and smoothing to help stabilize the display.
* Peak trace facility for better reading of fluctuating frequencies.
* Selectable signal decay speeds.
* Selectable signal gain control.
* Pause facility freezes the live trace to aid analysis of data.
Skini ovdje:
Kod:
http://www.megaupload.com/?d=93B51R9U
3. Jos komplikovanija, ARTA Audio Measurement And Analysis Software + Laptop
Za profesionalnu analizu zvuka
Welcome to the home page of the ARTA software - a collection of programs for audio measurements and analysis in acoustical and communication systems.
The ARTA software consists of following programs:
ARTA - program for the impulse response measurement and for real-time spectrum analysis and frequency response measurements.
STEPS - program for frequency response measurements with stepped-sine excitation.
LIMP - program for the loudspeaker impedance measurement and loudspeaker parameters estimation.
The ARTA program has functions of following measurement systems:
Impulse response measurement system with signal generators: periodic white noise, periodic pink noise, MLS, linear and logarithmic swept-sine.
Dual channel Fourier analyzer with signal generators: white noise, pink noise, periodic white noise and periodic pink noise.
Single channel Fourier analyzer with signal generators: periodic white noise and periodic pink noise.
Spectrum, octave band and THD analyzer with signal generators: sine, two sine, multitone, white noise, pink noise, periodic white noise and periodic pink noise.
With calibrated microphone, ARTA can be used as a virtual IECC class 1 SPL meter with real time modes:
Integrating SPL meter with 24 hours data logging,
Octave SPL meter with noise rating (NR, NC, PNC, RC, NCB),
Skini ovdje:
Kod:
http://rapidshare.com/files/218014955/ARTA.Audio.Measurement.And.Analysis.Software.v1.5.0-BEAN_cw.rar
4. Najednostavnija i najskuplja - Kupi amaterski db metar negdje tipa ovaj
49.99$
Kod:
http://www.radioshack.com/product/index.jsp?productId=2103667
Pozdrav
