Igru i citav folder od nje, ja bih predlozio neki uninstaller i registry cleaner, pa tek onda instaliraj frisko.
A mozes i ovo probati
1) Click Start, then Run.
2) At the prompt type "REGEDIT".
3) Click the "+" next to HKEY_LOCAL_MACHINE.
4) Click the "+" next to SOFTWARE.
5) Click the "+" next to Activision.
6) Click on the Call of Duty 2 folder.
7) On the right hand side, you should see an entry called Version. If you do not, skip to step 8. If it is there, make sure its value in the data field is 1.0.
8) On the right hand side, right click anywhere, and select New->String Value. Type in "Version" (without the quotes), and hit enter.
9) Right-click on the newly created string, and select Modify.
10) In the section marked "Value Data", enter "1.0" (without the quotes). Click on OK.
11) Reboot the system.
12) Install the 1.3 patch as normal. Do not install the 1.01 or 1.2 patch first; the 1.3 patch is cumulative.
@Joker - Nisam imao ovakvih problema, ali posto sam igrao CoD od 2003 preko neta, pa onda krenuo dvicu cim je izasla da igram, klanski, bili najbolji klan u bih, poosvajali masu turnira, i bilo je lijepo... izadje cetvorka i raspuhase se svi klanovi, a kolekcija demo-a od najpoznatijih klanova svijeta mi je na DVD-u... Ko god kaze da igrati zna svako debelo se vara, al da ne spamam dalje
