Maximum speed, km / h (INC / ACT) 282 (-)
Fuel tank capacity 63
Type Manual
Displacement, cc 3750
Location of valves and camshaft DOHC
Bore, Stroke, mm 101 x 78
Power, hp (kW) at RPM 328 (-) / 7300
Maximum torque Nm / rpm 260 / 4700
Number of Valves 4
Compression 10.5
Fuel AI-95
Automatic 6-speed Selespeed
Drive front
Class Body D
Number of doors (places) 4 (5)
Wheel base, mm 2595
Curb vehicle weight, kg 1460
Location Engine Front, transversely
tire size 235/40 R18
Disk Size 8.5x18
Front suspension Independent , double-lever, with antiroll
Rear suspension Independent, double-lever, with antiroll
Front brakes Ventilated discs, 355mm
Rear brakes disc, 276mm
Movement Pinion, power
Acceleration time from 0 to 100 km / h (INC / ACTs) 5.2 (-)
Type Manual
Number of Valves 4
Compression 10.5
Fuel AI-95
Drive front
Class Body D
Wheel base, mm 2595
Disk Size 8.5x18
