cijena 600 km
zamjene iskljucene
Uploaded with ImageShack.us
uredaj je bez ogrebotina sa svom dodatnom opermom(kablovi,upustvo,daljinski,futrola za plocicu,okvir,metalni rukavac za ugradnju)
CEA-2006 Power Ratings
CEA-2006 Power Rating: 4 I? @14.4V Ƈ%THD+N, S/N 80dBA (ref.1W into 4 I?), 18W x 4
Max Power Output Ratings
Max Power Output: 50W x 4
FM Tuner
Tuning Range: 87.7-107.9 MHz
Mono Usable Sensitivity: 9.3dBf (0.8 A?V/75 ohms)
50dB Quieting Sensitivity: 13.5dBf (1.3 A?V/75 ohms)
alternate Channel selectivity: 80.0 dB
Signal-to-Noise (S/N) Ratio: 65.0 dB
Stereo Separation: 35.0 dB
Capture Ratio: 2.0 dB
AM Tuner
Tuning Range: 530-1, 710kHz
Usable Sensitivity (IEC Standard): 22.5/27.0 (A?V/dBf)
Display
Screen Size: Motorized 7'' QVGA Touch Screen
LCD Type: Transparent Type TN LCD
Operation System: TFT Active Matrix
Number of Picture Elements: 336,960 pcs. (1,440 x 234)
Illlumination System: Cold Cathode Fluorescent Tube
Disc Player
Frequency Response: 5 - 20,000Hz
Channel Separation (at 1kHz): 85dB (at 1kHz)
Dynamic Range (at 1kHz): 95dB (at 1kHz)
Total Harmonic Distortion (at 1kHz): 0.008% (at 1kHz)
DAC Type: 24-Bit DAC
Wow & Flutter (%WRMS): B.M.L.
Oversampling: 8x/352.8kHz
Horizontal Resolution: 500 Lines or Greater
Video Ouput Level: 1Vp-p (75I?)
Signal-to-Noise Ratio (video): DVD: 60dB
Signal-to-Noise Ratio: 105 dB
Connection for iPodA?
MP3 Decoding: MPEG-1/2 AUDIO Layer-3
WMA Decoding: Windows Media' Audio
AAC Decoding: ACC-LC format ''/m4a'' file
Number of Channels: 2-Channel (Stereo)
Sound Tuning
Subwoofer Level Adjustment: -15dB to 0dB (1dB steps)
Bass Level Control Range: +/-14dB at 100Hz
Bass Center Frequency: 60/80/100/200Hz (selectable)
Bass Band Width Adjustment (Q): 4 choices (1 =wide, 4 =narrow)
Treble Level Control Range: 10k/12.5k/15k/17.5kHz (selectable)
Treble Center Frequency: +/-14dB at 10kHz
MediaXpander Modes: MediaXpander Modes: FM, CD, XM, MP3, (Level 1, 2, 3, Off), DVD Video (Level 1, 2, Off), DVD Music (Level 1, Off), (PXA-H100 Required)
MediaXpander Aux Settings: MP3, Music, Movie, (Level 1, Off), (PXA-H100 Required)
Equalizer: 5 Band Graphic / 7 Band Parametric Equilizer Ready (PXA-H100 Required)
Time Correction: 6 Channel Time Correction Ready (PXA-H100 Required)
Crossover: Off/80Hz, 120Hz, 160Hz (12dB/oct)
IMPRINT: IMPRINT Sound System Ready (PXA-H100 Required)
Remote Control
Remote Control: Included
Model Number: RUE-4203
Battery Type: (x1) CR2025
Dimension (WxHxD) mm : 51mm x 119mm x 13mm
Dimension (WxHxD) in : 2'' x 4-11/16'' x 1/2''
Weight: 40 g (1.4oz.)
Dimensions
Din Size: 1
Chassis Size (W x H x D) mm: 178mm x 50mm x 165mm
Chassis Size (W x H x D) in: 7'' x 2'' x 6-1/2''
General
Power Requirement: Power Requirement: 14.4 (11-16) V.DC
Pre Output Voltage (Before Clipping): 2V
Operating Temperature (A?C/ A?F): 60 A?C (140 A?F) to -10 A?C (14 A?F)
Maximum Mounting Angle: 30A? from Horizontal
Weight: 2.6kg (5 lbs. 12 oz.)
FEATURES
Tuner
Memory Presets: Preset Stations (FM:12/AM:6)
Memory: Auto
Seek Mode: Local/DX selection
HD RadioA?
Built-In or Ready: HD Radio Ready
Connection: Alpine TUA-T500HD Required
Signal Switching: Automatic Digital/Analog
Multi-Casting: Multi-Cast HD1, HD2, HD3
BluetoothA?
Parrot Bluetooth Module Built-In: Bluetooth Ready
Hands Free Calling: Hands Free Calling
Streaming Music: Streaming Music Playback
Streaming Music Control: Streaming Music Control
Connection: Alpine KCE-350BT Required. Features may differ between phone model and service providers.
Phone Book: Phone Book Transfer
Connection Type: Full Speed Connection for iPodA?
Connection for USB: Dedicated iPod Source
Connection: Full Speed Cable (KCE-430iV)
Compatibility for iPodA?/iPhoneA?: Full Speed Connection: 4th/5th Gen. iPod Video/Photo, iPod mini and iPod nano
Video Playback: Video Playback
M.I.X. (Shuffle) Capability: Song, Albums, All
Music Control: Song Up/Down/Repeat
Available selections: Playlist, Artist, Album, Song, Podcast, Genre, Composer
Percentage Search: Percentage Search
Information Display: Artist, Song, Album
Easy Navigating: Quick Search
Satellite Radio
Built-In or Ready: Satellite Radio Ready
Connection: SIRIUS or XM Adapter Required
Satellite Provider Capability: SIRIUS or XM
Preset Memory: 3-Bands (6 Per Band, 18 Channels Total)
Easy Navigating : Quick Search
Music Information: Category, Artist, Song
Portable Compatibility: SIRIUS Plug N Play Devices (Adapter Required)
Disc Player
Disc Type: DVD Player
Disc Playback Type: DVD / DVD Audio / DVD Video / DVD-R / DVD-RW / DVD+R / DVD+RW / VCD / CD / CD-R / CD-RW
Music Playback: MP3/AAC/WMA/DivX Playback
DAC: 24-Bit DAC
Zero data Mute: 0 Bit Mute
Digital Servo: Digtal Servo
Music Sensor: Scan/Repeat
Playback Control: Play/Pause/Forward/Back
Title Memory: 18 Disc Title Memory Display (Disc Only)
M.I.X. Mode: One (Folder)/All (Random Play)/Random (CD Only)
Sound Tuning
Subwoofer Level: Subwoofer Level Adjustment
Bass Level: Bass Level Adjustment
Bass Center Frequency: Bass Center Frequency Adjustment
Bass Bandwidth Adjustment: Bass Width Adjustment
Treble Level: Treble Level Adjustment
Treble Center Frequency: Treble Center Adjustment
MediaXpander: MediaXpander Adjustment (PXA-H100 Required)
Crossover: Built-In High-Pass /Low-Pass Crossover
CD Changer Control
M.I.X.: One/All (Shuffle)
Multi-Changer Control: Multi-Changer Control Including MP3 Changer CHA-S624, (with KCA-410C)
Music Text Information: CD:Text Scroll Display, MP3: Text Information Display (ID3 Tag)
Music Control: Play/Pause/Forward/Back
Repeat: Song/Disc
General
Power Output: 50W x 4 High Power Amplifier
CD Changer: CD Changer Control
Display: Monitor
Control Type: Rotary Encoder Knob
iPersonalize: Data Download
Face Color: Gunmetal Black
Illumination Buttons: Blue Illuminated Buttons
Playback: DVD Video, DVD-Audio, DVD-VR, VCD, CD-DA, MP3/WMA/DivX
PreOut: 3 PreOut (2V PreOut)
BluetoothA?: Bluetooth Ready
DAC: 24-Bit DAC
Steering Wheel Control: Steering Wheel Control Ready
Bass & Treble: Bass & Treble Controls
Fader & Balance: Fader & Balance Controls
Clock: Built-In Clock
Detachable Face Plate: Detachable Trim Plate
Dimmer: Dimmer Input
Power Antenna Lead: Power Antenna Output
Remote Turn-On: Amplifier Remote Turn-On Output
Audio Interrupt: Audio Interrupt Input
Mute: Built-in Audio Mute
Remote Control: Remote Control Included
zamjene iskljucene
FM Tuner
AM Tuner
Display
Disc Player
Sound Tuning
Remote Control
Dimensions
Din Size: 1
General
FEATURES
Tuner
Memory: Auto
HD RadioA?
BluetoothA?
Satellite Radio
Disc Player
DAC: 24-Bit DAC
Sound Tuning
CD Changer Control
Repeat: Song/Disc
General
Display: Monitor
DAC: 24-Bit DAC
