toxic wofer tsw 120f i pojacalo mac mpx2000
prodajem navedeno pojacalo i wofer ili mjenjam za bixenone,mobitel ili slicno.
evo spec
MAC Audio amplifier. Produces good sound and easy to change settings.
Below is the specification for the amp:
Output *
at 4Ω 2x180 / 1x500 watts
RMS power output ** into 4 Ω 2x60 / 1x150 watts
Output *
at 2Ω 2x250 Watt
RMS power output ** into 2 Ω 2x80 Watt
Frequency response 5-50 kHz (-3 dB)
THD <0.05% (1 kHz)
Noise floor > 100 dB
Input sensitivity 0.4 to 4 V
Dimensions (WxHxD) 239 x 59 x 226 mm
Input impedance 20 kOhm
Power supply 12 V negative ground
Weight 1.9 kg
Extras
2 ohm stable
Variable low pass 40 - 300 Hz (12 dB / octave)
Variable high pass 40 - 300 Hz (12 dB / octave)
Variable Bass Boost 0 .. 12 dB at 45 Hz
Bridge-operation
Circuit protection against short circuits, DC-offset and overheating
Power indicator (green LED) and overload indicator (red LED)
navedeni woofer je u kutiji
Toxic TSW-120F ( Free-Air )
12" Free-Air Subwoofer,
1000 Watt, rot-metallic
Durchmesser 12" / 300 mm Belastbarkeit,
maximal 1000 W Belastbarkeit,
RMS 500 W
Impedanz 4 Ohm
Frequenzbereich 20 Hz-2 KHz SPL 87 dB
Einbautiefe 160 mm
sve info na 062841683 moze sms
cijena 150 u zamjenu 180km
Prilozi
    28,3 KB · Pregleda: 0
    18,3 KB · Pregleda: 4
