stara serija X type zvucnika sa skretnicama, nosacima tweetera i svom ostalom opremom originalne mrezice za zvucnike itd itd
cijena 200 EUR
* Sensitivity: 86 dB
* RMS Power Range : 60 Watts
* Peak Power Handling: 240 Watts
* Frequency response: 40-35000 Hz
* Diameter: 5.25 Inch
# Wood Fiber Cone & Phase Integrated Dust Cap
# Non-Resonant Suspension Coupling (NRSC) with Reinforced Edge
# Low Resonance Multi-Roll Surround (LRMS)
# Braided Low-DCR Tinsel Leads
# Custom Cast Aluminum Frame
# Integrated Spider Landing & Vented Heat Transfer Plate
# FEA Optimized CRC T-Drive Motor Structure
# Airflow Optimized Dual-Flare Pole Vent
# High Quality Synthetic Black Spider
# Single Voice Coil Design, 4-Layer Copper Clad Aluminum (CCA) Wire on Glass Fiber Bobbin
# High Grade Strontium Ferrite Magnet
# Gold Plated Terminals
# Snap Fit Mounting System
# 32mm (1") Ring Radiator Diaphragm with Wave Guide
# 19mm Voice Coil, Copper Clad Aluminum (CCA) Wire on Aluminum Bobbin
# Periphery Venting System into Cast Aluminum Tuned Chamber with Integrated Heatsink
# Low Distortion Motor Structure with High Grade Neodymium Magnets and Copper Shorting Cap
# Twist Lock Installation Ring with Compact Swivel System
# Phase Coherent Design
# Integrated Level/Axis Adjustment
# Tweeter Protection Circuit
# Bi-Amp/Bi-Wire Capable
# 3-Way/Dual Midbass ready
# Ultra-High Grade Passive Components (Metallized Poly Capacitors, Heavy Gauge Air Core Inductors, Low Tolerance Heatsink Resistors, OFC Circuit Board Traces)
# Gold Plated Terminals and Connection Jumpers
cijena 200 EUR
