woofer DLS KW12 BEZ KUTIJE - 100KM
woofer je kao NOV![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
BEZ ZAMJENA
evo specs
Woofer size 12" (30 cm)
Impedance 4 ohm
Power handling capacity RMS 250 W
Max power handling capacity 500 W
Peak power 750 W
Frequency range 20 Hz - 2 kHz
Sensitivity 91,2 dB
Magnet size 120 mm (4,72")
Outer diameter of woofer 310 mm (12,12")
Mounting depth 133 mm (5,24")
Mounting hole 278 mm (10,94")
X-max +-9 mm
Weight 4 kg ( 8,8 lb)
T/S parameters
single V/C
Fs 33 Hz Re 3,1 Ohm Qms 3,57
Vas 113 liter Vas 4 Cuft Qes 0,48
Qts 0,42 Sd 491 cm² BL 9,58
woofer je kao NOV
BEZ ZAMJENA
evo specs
Impedance 4 ohm
Peak power 750 W
Sensitivity 91,2 dB
X-max +-9 mm
T/S parameters
single V/C
![4221-1_prod_large.jpg](http://dls.se/prodimg/4221-1_prod_large.jpg)
