![10042012321.jpg](http://img809.imageshack.us/img809/2608/10042012321.jpg)
http://imageshack.us/photo/my-images/713/10042012324.jpg/
http://imageshack.us/photo/my-images/26/10042012328.jpg/
VELICINA JE XXL (23" ILI 23,5"),ZA OSOBE 190+cm
FRAME Specialized M4 fully manipulated alloy frame, fully butted, ORE DT, externally relieved HT, forged dropouts w/ replaceable derailleur hanger
FORK SR Suntour SF9-XCR-LO, 80/100mm, 1 piece magnesium lower, alloy steerer, hydraulic damping w/ LO and preload adj., size-specific spring rates, spring assisted seal
HEADSET 1-1/8" threadless, loose ball
STEM 3D forged alloy, 7 degree rise, 31.8mm clamp
HANDLEBARS Butted alloy riserbar, 25mm rise, 660mm wide, 8 degree back sweep, 7 degree up sweep
GRIPS Specialized Enduro, dual compound Kraton, no flange, 131mm
FRONT BRAKE V brake, alloy linear pull, 1pc. pad
REAR BRAKE V brake, alloy linear pull, 1pc. pad
BRAKE LEVERS Alloy, linear pull
FRONT DERAILLEUR Shimano Altus, 34.9mm clamp
REAR DERAILLEUR SRAM X-5, mid cage
SHIFT LEVERS SRAM X4-R trigger
CASSETTE SRAM PG-830, 8-speed, 11-32t
CHAIN KMC X8 w/ reuseable Missing Link
CRANKSET SR SunTour, Octalink spline
CHAINRINGS 42S x 32S x 22S replaceable
BOTTOM BRACKET Shimano BB-ES25, Octalink spline, cartridge bearing, 68mm x 118mm
PEDALS Steel cage, composite body, 9/16"
RIMS Alex RH 26, alloy double wall, CNC sidewalls, 26h front and 28h rear
FRONT HUB Forged alloy, double sealed, ground race, steel QR, 28h
REAR HUB Shimano RM30, forged alloy, double sealed, ground race, cassette, 32h
SPOKES 2mm (14g) stainless
FRONT TIRE Specialized Fast Trak LK Sport, 26x2.0", 60TPI, wire bead
REAR TIRE Specialized Fast Trak LK Sport, 26x2.0", 60TPI, wire bead
INNER TUBES Schraeder valve
cijena 730KM, nije fiksno
