P:SIGNAT ROC 1
P:SIGNAT ROC 1
Prodajem navedeno pojacalo cijena 110km,u slucaju kvara servis obezbjedzen o mom trosku u roku 2 mjeseca...
Specification data:
Amp type: 4 channel
Pc board: double sided
Power terminal: gold plated screw type
Speaker terminals: gold plated screw type
Signal input terminals: 4 x RCA jacks gold plated
BIC balanced input circuity
Bridged mode: yes (min. 4 Ohm)
Trimode operation: built-in
Protection and control circuites: Temperature, overload, short circuit,
DC offset
Output load impendance (stereo mode): 2 - 8 Ohm
Active low pass filter: 80Hz, 12dB (ch front & rear)
Active high pass filter: 110Hz,12dB (ch front & rear)
Technical data:
Max. peak music power: 400W
RMS power at 4 Ohm (0,05% THD): 4x50W
RMS power at 4 Ohm (0,1% THD): 2x140W
RMS power at 2 Ohm (0,2% THD): 4x70W
S/N ratio (A-weighted): 105 dB
Freq. response (-3dB): 10-50 kHz
Stereo separation: 70 dB
Input sensitivity: 150mV - 4V
Input impendance: 20 kOhm
Fuse rate: 30A
Supply voltage: 12 V DC
Dimensions: 192 x 55 x 380 mm
images
zanima me dali na ovo pojacalo moze da se skopca 1 zvucnik i pri tome iskoristi maximalnu snagu 400w na jednom izlazu?
pozz
.::stjepa::. je napisao(la):
pozz
moze ako ima 2 zavojnice al nije preporucljivo
