Prodajem pojacalo Rockford Fosgate T1500-1bd, cijena 600 KM, ili dajem njega i 2 DD M1a za jedno jace pojacalo.
Power Series Compact Class bD Amplifier
RMS Power Output:
4 ohms: 500 watts x 1 channels
2 ohms: 1000 watts x 1 channels
1 ohm: 1500 watts x 1 channels
1-Ohm Mono Stable
CEA 2006 standard ratings for real-world power
High Efficiency Class bd Topology
Variable 35-250 Hz Low-Pass Crossover
24 dB/Octave Butterworth Crossover Alignment
Variable 0–18 dB Punch Boost @ 45 Hz
Infrasonic filter: -3dB @ 28Hz 12dB/Octave
Removable Connections Shroud
4 Gauge Power & Ground Connections
Preamp Outputs
Wired Remote Punch Bass EQ port (P-EQ sold separately)
Bass boost: 24 dB
Frequency Response: 20-250 Hz
Dimensions: 8-3/20"L x 14-9/10"W x 2-3/20"H
1/0-gauge power and ground leads recommended. Contact us for information regarding a discount on a select amplifier kit when purchased together.
Sent from my HTC Sensation XE with Beats Audio Z715e using Tapatalk 2
RMS Power Output:
1-Ohm Mono Stable
Preamp Outputs
Bass boost: 24 dB
