P: RE MT 15" 2kom!!!
Jedan 550evra
Dva 1000evra
Mounting Depth - 9”
Mounting Hole Diameter - 14”
Overall Diameter - 15.5”
Bolt Hole Circle - 14.75”
Motor Width - 9”
Motor Depth - 4.5”
Basket Depth - 4.5”
Displacement - .21 cu. ft.
Weight - 61 lbs.
Kraft Pulp Cone w/Carbon Fibers in Matrix
Rubatek Foam Surround
Cast Aluminum Basket
Foamed Core Dustcap
Tork-Tite Terminal
8-layer Aluminum Voice Coil
FEA Optimized Motor Structure
Triple Stack Magnets
Dual, Triple, or Quad Progressive Spiders
Wrap Around Rubber Gasket
moze zamena za AMP/slabiji woof ili nesto slicno
Recimo 2x10" neke brutale APXX CS DD
Cak i moja doplata za neke stvari
AJMOOOOO 155+db easy sa ovim bebama i 5kw
